Old 06-15-2010, 04:37 PM
Nvrgvup Nvrgvup is offline
Boat: 1983 S&S
Re-Mounting Swim Platform
I have been polishing, polishing and polishing the new boat. Really looking good.
Had a little movement in the platform, not much. The bolts look like they had been replaced. So I pulled it off. I found that the previous owner had reattached it using metal concrete anchors. At least he sealed it well and did it only on the top two bolts on each bracket. Pulled the gas tank and drilled the inside of the anchors so I could pull them out. Wood looked good. The back of the anchors were visible just slightly above the floor. I am going to through bolt the top two, lag the bottom ones and through bolt the mid support. Just don't feel like cutting the floor at this time. I did see another poster do this and it seem like it worked well.
Question:
The top holes that the anchors were in are probably about 5/8". I was going to try to use 3/8" bolts that will need to be placed at the top of the holes. I was thinking of epoxying the holes solid and then re-drilling. Then I thought this may be a bad idea if when I tighten everything up the epoxy slug will bottom out or bust loose and prevent good compression. So I was then thinking of just filling the holes and sealing everything up with 5200.
Any suggestions, Thanks!!
Old 06-16-2010, 11:48 AM
Luv2Ski's Avatar
Luv2Ski Luv2Ski is offline
Boat: 1988, ProStar 190, 351w
If the holes are 5/8", why not use 5/8" bolts?
I think you will be fine with the lag bolts on the bottom assuming the wood is in good shape.
You should be able to fill those holes with epoxy . Be sure they are planner with the surrounding surfaces so that the load is transferred outside the slug. That said, it it a challenge to put that much epoxy on a vertical surface unless you are laying up glass which is a more involved process (requires tapering the holes to a larger size).
I would probably go with the sealant option as well. Just use a large fender washer on the inside so the load is applied to the existing structure.
Boat: 1983 S&S
I would go with some bigger bolts I just can get a nut and washer on the backside without cutting the floor up. Too close to the floor. I have backing plates made for the inside.
I would like to epoxy the and then redrill however I may just seal it all up. Regradless the epoxy or sealant is just acting as a filler.
I am also considering making a larger backing / adapter plate out of 1/2" aluminum maybe 5" x 6" mouting that to the outside of the transom and then bolting the existing brackets to that.
Old 06-22-2010, 07:13 AM
ecproductions143's Avatar
ecproductions143 ecproductions143 is offline
Boat: MASTERCRAFT S&S 1908 350 1.52:1
in my 80 i can get to all of them withtout messging witht he floor . Floor stops fuel tank
COLOR="DarkRed"]1980 S&S 350 1.52:1 14.25x14 OJ[/color]
Old 06-23-2010, 11:53 AM
83MC 83MC is offline
Boat: 1983 S&S PowerSlot
What I did a couple of years ago
Back plate top two bolts only...
Old 05-21-2013, 02:05 PM
LGP LGP is offline
Boat: 1985 MC SS
NV.... this is a great help. I will remove the fuel tank today and see what I have to work with. Many thanks!
Old 05-21-2013, 02:54 PM
You're welcome...Please post pictures of your work, everyone really enjoys the pics on this board.
Old 05-22-2013, 05:38 PM
John 3:16-18
Old 05-23-2013, 10:36 AM
I respectfully disagree with “cloaked”. You will achieve a good seal if you fill the bottom, and top holes with 3m 5200 before you install the bottom lag and top bolts.
Old 05-23-2013, 08:02 PM
John 3:16-18
