V-drive Transmission oil
I have an '01 v-drive (630V) and have always used ATF as specified in the manual. I now see MC recommends 15/40 motor oil. I read the Mobil 1 post below looking for a reason for the change but did not see one. Does anybody know why the changed the specification and the benefits? If making the switch, is a synthetic ok? Should it be changed twice to ensure all ATF is out, or will a little mixed in do any harm?
Tom023,
I also have a v-drive (HSW 630 V1) in my 99 Maristar 210, and I also saw that the new specs call for oil rather than ATF. However, I would stick with the ATF as it appears that Hurth now markets the v-drive tranny under a different model name (ZF 630 IV), so it could be the same internal "guts" or it could be different. http://zf-marine.com/ Last edited by Kell; 08-22-2004 at 11:51 PM. |
I THINK I read somewhere that the switch to motor oil was because owners were complaining about the 'gear noise' - same tranny, but runs quieter on motor oil. Anybody else recall this?
2002 MariStar 210 VRS 330hp, Tower, Perfect Pass Stargazer, Bimini, Triple KGB Ballast, 400w Clarion XMD3, Bennett X-14 Wake Plate Life is not a journey to the grave with the intention of arriving safely in a pristine, well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming "-- WOW--What a Ride!"
Well since I have 5 qts. of ATF still sitting in the garage, this year's change will be ATF. I don't think I have any gear noise, sounds the same as it always has. I guess I won't know unless I make the change to oil.
Neil, do you run ATF or oil? |
