Old 06-07-2010, 03:39 PM
demonts's Avatar
demonts demonts is offline
Boat: 2002 Prostar 197 TT, LQ9
Replacing LQ9 exhaust manifolds
Gents,
The exhaust manifolds need to be replaced on my 2002 Tournament Team with the LQ9 engine. So far, I've only been able to locate the replacements directly through MC. Does anybody know if this is my only option? Do I need to replace with cast aluminum? Any recommendations as to who else carries an exhaust manifold that is compatible with this engine? I have the MC part numbers if that helps.
Old 06-07-2010, 03:40 PM
03 35th Anniversary's Avatar
03 35th Anniversary 03 35th Anniversary is offline
Boat: Searching
Originally Posted by demonts View Post
Gents,
You maybe able to find something thru indmar.
Not sure of that.
Old 06-07-2010, 06:07 PM
JLeuck64's Avatar
JLeuck64 JLeuck64 is offline
Boat: 98 Prostar 190 Stars & Stripes, LT1
http://www.hitekmarine.com.au/
These guys have a beautiful product... Spendy I am sure but if I ever need a set of new manifolds I would consider these!
Need LT-1 parts?
89058397 (pump outlet side)
Old 07-13-2010, 07:19 PM
demonts's Avatar
Just closing the loop on this. I decided to go OEM through the dealership where I bought my boat. It was significantly cheaper to go through a US dealer but the parts were pricey.
cast aluminum, exhaust manifolds, lq9
