Optima Blue Top Frustration
after this weekend I will be taking back my third Optima Blue top for a warranty replacement. They will not hold a charge for more than a few hours. Driving me crazy. Alternator is charging fine, I put a 10 amp charger on it and it seems to charge fine then loses it sitting there. Same if I put it on the trickle charger. It will start fine once I get it started for the day but each morning I have to put the charger back on.
Only thing on in the boat is the auto bilge so I doubt that is draining it. Anyone else ever had a problem like this?
This board be a changin...
Mine only lasted 9 months. I won't buy another.
Sear platnum batteries are made by Odessey are very good. I would have the boat checked for a draw on the battery to be sure the problem is with the battery.
06 AWSA Approved Towboat |
2nd the sears platinum AGM for starter battery. Had a bluetop and it was junk
___________________________________________ ________________________________ |
I've had a blue top now for 2 years, no problems. I have 2 amps drawing off of it too.
Must be the luck of the draw. I've had a red top in my 66 Mustang track car now for 6 years and it's still OK.
-Mark- 1996 Prostar 190 |
I had 3 red tops in my old boat (no stereo really, just a starting battery). The first 2 lasted 2 years each and then wouldn't take a charge. Both replaced under warranty. Used the 3rd one for 1 season in my old boat and then switched it to my old Jeep. At the time I swore I'd never buy another Optima. Now that 3rd battery is going on 3 years old in the Jeep that never gets driven, sits outside alot, even in the winter, never maintain the battery, only start the Jeep long enough to move the snow from around it or push the boat in/out of the garage, and it works great.
Just got a Optima Blue Top for a start battery in the new boat a few months ago. So far, so good. It was $100 cheaper than the Odyssey I have for my house battery and available locally when I needed it, otherwise I wouldn't have bought it.
Going on second year with Blue tops. Haven't done a thing to them and have had no issues. Hoping for the best.
Optima
I had no issues with Optima battery's until this year 2009 / 2010. I replaced 3 Blue Tops. 1 in the boat ( only 1 year old ) and 2 in my Rx7. No issue with current drain in the boat, I think the Sterio was to large for the battery capacity of the Blue Top and the constant discharge and recharge form the altenator killed the battery.
I went to 2 much larger interstate sealed batteries and a really good conditioner / charger in the boat. I think the car was the same type deal, very large system only so much the altenaotr can do.... We'll see if the other brand holds up this year. Rob |
My first one was good for a season before I killed it leaving something on and couldn't get it to recover. My second one drained and I couldn't figure out why, but I was able to get it to recover doing the inline charge trick with my truck and then topping it off with my trickle charger. I had tried to charge it using a normal charger, but it kept overloading and shutting off and I didn't want to spring for the special charger they supposedly need.
So far, it appears that I recovered the cells successfully as the battery held charge all winter and started the boat fine when I pulled it out last week to dewinterize. The first test is to see if it drains while hooked up in the boat for 3 weeks without being run. I'm concerned about it. If this one goes, I'm gonna switch to an Interstate.
'06 X-1, it's red and white. |
We've got boat owners that are well into their 4th year with Optima Blue Tops and still going strong.
A Blue Top Group 34 is a short battery, smaller and lighter than a Group 24, and only has 55 amp/hours capacity. Any battery that cycles deeper will provide fewer total cycles. So have enough reserve capacity that the batteries don't fall below 12 volts. And get a real smart multi-stage dual-bank charger that is equal to at least 10 percent of the total amp/hours capacity. Don't depend on trickle/tender chargers (okay for UTV, ATV, motorcycle, 3rd cars, etc, with starting batteries) and don't depend solely on your alternator. We haven't encountered a bad line of batteries in our experience (several hundred boat installs per year), just bad charging schemes and disciplines. Btw, if you're using an ACR/VSR you're even more dependent on an AC shore charger for restoration. You can generally judge a battery's capacity by weight. Regardless of specs the lighter batteries don't last as long. David Earmark Marine |
