Old 06-02-2010, 01:08 PM
nwhittuk10 nwhittuk10 is offline
Boat: Mastercraft Prostar 190 1990
Bad Vibration over 2500 rpms
Took my boat out for the first time this year and discovered it had a bad vibration in it? I felt this as soon as I started the throttle and never felt it last year. Could it possinbly be because of something the guy did while winterizing it over the winter? Could it possibly be something else? While pulling a wakeboarder the vibrationm isn't really bad, but when running it wide open it is almost impossible to hold onto the steering wheel because it vibrates so bad. Any suggestions would be greatly appreciated. Thanks ahead of time!
Old 06-02-2010, 01:13 PM
mrprostar's Avatar
mrprostar mrprostar is offline
Boat: 1996 Prostar 205
Bent prop or driveshaft or shrut or out of alignment. That bad of vibration would be caused by noticable damage, I would think.
1996 Prostar 205
Old 06-02-2010, 01:59 PM
Hollywood's Avatar
Hollywood Hollywood is offline
Boat: MasterCraft, ProStar 209, 2003, MCX
Well if you're sure there is no damage since last fall I wouldn't suspect the drivetrain. Checking the bottom for damage, shaft alignment, and swapping a different prop would be zero cost diagnosis.
Is the engine running smooth?
Old 06-02-2010, 02:40 PM
Hey thanks for the suggestions guys. How would I go about seeing if the shaft is out of alignment and is it something I could fix myself? Yes, the engine runs fine I was just afraid to really run it because of the vibration. It seemed to take off as well as it has in the past and have as much speed. The prop is somewhat bent, but nothing more than it was at the end of the year last year, which leads me to think its not that.
