Old 06-25-2012, 10:19 AM
MariStar-Man's Avatar
Boat: 1999 Maristar 210 VRS
Originally Posted by Hogwild View Post
Maristar-Man...where did you end up purchasing this unit from? I need a replacement and can't find anyone open to tell me what part number it is or where I could order it from. Thanks.
Hey Hog, Just gettin back into town. We were at Lake Tulloch, but in answer to your questions...
You will have to remove the old sender and measure how far your sending unit tube sticks into your tank, and possibly cut the new one to be an exact match. Then count the number of wires on the old unit and match the new. Go here and call these guys up and let them know what you have. http://www.skidim.com/products.asp?dept=1088 Phone / (803) 345-0996
It's pretty simple with those two facts in hand. Oh lastly, make sure you don't use any electrical devices or battery operated screw-guns near tank. Just the hand held screwdriver, or you might not need a sending unit after all...
1999 MasterCraft Maristar, V210, 330 Hp LTR
Mods: Upgraded Stereo, Amp, 6 Disk Changer, Zero-Flex Tower, Custom Fit Bimini Top, and of course...Teak Oil!
Old 12-18-2012, 11:57 AM
Hogwild's Avatar
Hogwild Hogwild is offline
Boat: n/a
I'm still having trouble identifying the part that I need. My sending unit looks like it only has 2 wires and there is no float involved. It only has a silver tube approx 9.75 in. long. Do you guys with similar models know which route I should take to get a good replacement?
Old 12-18-2012, 12:00 PM
Hogwild's Avatar
Boat: n/a
Here's a picture of the unit
Old 12-18-2012, 12:16 PM
Hogwild's Avatar
Boat: n/a
I also found this thread which looks like a picture of the unit I have, but no final reply was ever posted to know if Jeff used the Centroid product as his solution.
http://www.mastercraft.com/teamtalk/...ad.php?t=38102
Old 12-18-2012, 01:25 PM
SP Maristar's Avatar
Sounds like your 99 is just like our 98 Maristar one. Ours looks similar on top, is a two-wire unit, and has an aluminum tube like yours. The float is inside. If you tip is back and forth, you can hear and feel the float rise and fall. Our problem ended up being a magnet that had come loose from the float. Very common. I took the unit apart, found the magnet, glued it back on the float with epoxy, and it has been working fine ever since. I believe there were numbers on mine, where I could call somewhere like skidim and have them help me with a replacement part.
Old 12-18-2012, 01:30 PM
Just read the rest of the post. Our aluminum tube was about 1" in diameter with a black plastic plate screwed on the bottom with two small screws. The sender pictured earlier in this post does not look like mine. Perhaps they are different. Ours was an isspro model also, but the length sounds about right.
Old 12-18-2012, 02:22 PM
mtajpa's Avatar
mtajpa mtajpa is offline
Look for my "Fuel Sender 101" thread it will show you what the 99year Maristar models have.
http://www.mastercraft.com/teamtalk/...ad.php?t=48823
There are no floats on these units.
99 MariStar 230 Sport LTR 330
Old 12-19-2012, 10:09 AM
Hogwild's Avatar
Boat: n/a
Do you have the picture of the older model saved on your computer? I'd like to see what the model number is. Great lakes skipper has some centroid sender units that may match that OEM model exactly, but I can't tell what the numbers read. Thanks
Old 12-19-2012, 10:26 AM
mtajpa's Avatar
I post a better pic later its on a different pc. I wasn't able to fine an exact replacement when I was looking. That is why I went with SKIDIM.
Old 12-19-2012, 12:02 PM
mtajpa's Avatar
He is the best picture I have it has the numbers you should need. Did you attempt to adjust yours? The adjustment screws are covered with silicone.
