  #291
Old 02-23-2014, 09:18 PM
John 3:16-18
Old 02-23-2014, 09:24 PM
MLA MLA is online now
Boat: pontoon
Originally Posted by _fng_ View Post
Forgive my ignorance but for "house loads" (top Left connection as shown on pdf below), all I have hooked up to the perko switch is my sub amp. What should be set up to the house loads connection? My single battery set up was 2awg from the engine ground and to the starter. Should there be more to the "house loads" connection other than the sub amp?
side note, both batteries read 12.7x on volt meter with engine off (without putting on trickle charger).
Thanks a lot for helping me out!
http://assets.bluesea.com/files/reso.../990310020.pdf
A "house load" is anything you want to run when the engine is off and have it draw off the newly installed "house bank"
Your head-unit should also be connected house bank. Odd are, its drawing off the cranking as it originally was.
Old 02-23-2014, 09:30 PM
Boat: pontoon
At the batteries, I have nothing other than the engine power, engine ground, and sub amp power/ground. Should I do something with the ignition switch wiring? Side note, I rewired PP power to ignition switch to help with voltage drop from PP.
The only cables connected directly to the battery B+ posts are the cables going to the #1b and #2b posts and the auto bilge.
Nothing needs to be done to the key switch when installing the add-a-battery
_fng_'s Avatar
_fng_ _fng_ is offline
Boat: Prostar 205
Thanks for the help guys! If I could buy you guys a beer, I would!
Old 02-23-2014, 09:33 PM
Boat: pontoon
As it was "optional" I did not install this part of the diagram. Eureka??
You do need to wire up the SI terminal. I dont think thats your issue.
Old 02-23-2014, 09:36 PM
_fng_'s Avatar
Boat: Prostar 205
Do you mean do not need to wire SI terminal? In your previous post you say that I don't need to mess with ignition switch. Do you think the head unit connected to cranking battery could draw enough load to cause a hesitation in starting?
My next step will be running a SI to the ignition to see if it reduces the hesitation when starting...other than that, I may take it somewhere.
Here is what mine looks like.
Old 02-23-2014, 09:47 PM
Boat: pontoon
Sorry, need to make an edit here! I left out NOT
You DO NOT need to wire the SI terminal. its getting late, my eyes are tired and im watching the race that should have already been run
Old 03-10-2014, 11:38 AM
kblanch09 kblanch09 is offline
Boat: N/A
Does the isolated relay allow you to always be able to start the engine even if the aux battery is dead?
Old 03-10-2014, 04:24 PM
Kweisner's Avatar
Kweisner Kweisner is offline
Boat: 2007 Prostar 197
The Official Dual Battery Thread
^ If you are referring to the original setup posted by Diesel on page 1, then yes, that is the basic premise. If you read back in this thread you will see there are those folks that say once you join the drained AUX/house battery with the starter battery, there is a chance that the starter batt will be drained by the house batt. Technically this is true.
Practically speaking, the period of time between when the batteries are coupled and the starter is engaged is going to be less than a second or two, so I don't know if this is a legit concern. I have the isolator setup, and so far, I've never had a starting issue and I enjoy not worrying about switch positions, my memory, etc.
"This one goes to eleven." 2007 ProStar 197 TT w/MCX and Powerslot.
Old 04-04-2014, 05:59 PM
chooverton chooverton is offline
Boat: 96 Mastercraft Prostar 205
I am finally going to install the SR200 i have had sitting in the garage for 6 months this weekend. Quick question, i have searched all over and couldn't find an answer, although i bet it is here. What Gauge wire do i need for the non-battery connections? Would some 12 GA primary wire work for both the ignition and ground wire (small terminals). I am using 0 gauge for the battery cable. May be be overkill but i got a deal on it. Thanks
amp, ballast, batteries, stereo, system
