  #271
Old 11-03-2013, 09:34 PM
John 3:16-18
Old 11-03-2013, 11:30 PM
Timdog145 Timdog145 is offline
Boat: 1989 Mastercraft ProStar 190 351ci
battery location 89 prostar
Cloaked,
Thanks for all of the great info. I certainly understand the concept of screwing into the flat floor area vs the sloped hull area of the bow. I just wasn't familiar with the construction of the flat floor area and how it would be affected by screwing into it. And you answered my question on the battery box. I know now that when it comes to removing the battery for replacement/ winterizing I would be able to slide the box out in order to remove the battery and it wouldnt be permanently fixed to the floor.
Great info on a source for the cables as well.
My most significant concern was being able to screw into the flat (non-hull) floor area.
As I said, I am a brand new first time owner and you can expect to see a lot of questions from me all over Team Talk.
Thanks again for your help.
Tim
Old 11-19-2013, 01:37 PM
imyourmaster's Avatar
imyourmaster imyourmaster is offline
Boat: 2008 X-2
The Official Dual Battery Thread
Can anyone shed light on a dual battery setup in a 2008 X2? I have two batteries which are not paralleled from what I can tell. One battery has cables marked "house" connected to it and the second battery has cables marked "starter" connected to it. These cables run to a 3 way blue sea battery selector switch (off/on/combine). When in the "on" position both batteries are live but isolated. So...why does my stereo stop playing if I disconnect the "starter" battery? This does not make sense to me...what am I missing?
Thanks!
Old 11-19-2013, 02:41 PM
Quinten Quinten is offline
Boat: 1997 Crownline 182 (sold), 2012 Mastercraft X2
Originally Posted by imyourmaster View Post
Can anyone shed light on a dual battery setup in a 2008 X2? I have two batteries which are not paralleled from what I can tell. One battery has cables marked "house" connected to it and the second battery has cables marked "starter" connected to it. These cables run to a 3 way blue sea battery selector switch (off/on/combine). When in the "on" position both batteries are live but isolated. So...why does my stereo stop playing if I disconnect the "house" battery? This does not make sense to me...what am I missing?
Thanks!
From what I know about is that the house battery is for stereo and accesoirs etc. And the starter is for starting the engine so if you play to long on the stereo. Than you are abble to start the boat again.
Old 11-19-2013, 04:09 PM
Boat: 2008 X-2
Sorry guys...I had to edit my original post. I had originally asked why my stereo would stop playing when I disconnect the "house" battery. What I meant to say was when I disconnect the "starter" battery.
Old 11-21-2013, 04:07 AM
Sorry can't help with that. Would to know the answer to.
Never tryed its with a 2012 x2.
Old 11-21-2013, 07:35 AM
Kweisner's Avatar
Kweisner Kweisner is offline
Boat: 2007 Prostar 197
Could it be that one of the 12v trigger leads is commected to the starter batt circuit? IOW, house batt is providing the consumptive power for the head unt and amplifiers, but the on/off trigger is tied out to the other batt and when disconnected, there's no trigger voltage.
"This one goes to eleven." 2007 ProStar 197 TT w/MCX and Powerslot.
Old 11-27-2013, 08:52 AM
Boat: 2008 X-2
Thanks for your reply! It made me think about the possibility...However, my 12v trigger lead runs directly from the head unit to the amplifiers. For whatever reason may be, the head unit loses power when I disconnect either of the house or starter battery. I will talk to the guys at Blue Sea today. It could be that the connections on the back of the battery selector switch are wrong.
Old 11-27-2013, 02:01 PM
mgs96ps mgs96ps is offline
Boat: A
Sorry to tread jack...but could someone point me to a post that I was reading a couple weeks ago about best battery tender/ battery charger for winter? Thought I would ask here instead of start new post.
Old 02-23-2014, 08:55 PM
_fng_'s Avatar
_fng_ _fng_ is offline
Boat: Prostar 205
So last weekend I added the blue seas add a battery system with a starting and deep cell battery. Today we were sitting listening for music for approx 1.5 hrs and when I tried to start the boat it took 3-4 turns to get it to turn over. I would have thought the relay would have transitioned to the starting battery automatically without need for a few turns. Does this mean I did not install it correctly? Any trouble-shooting advice before I call blue seas tomorrow?
fyi, I used 2 gauge wire for all set up and 100 amp fuse for relay (as described in the instructions), i only have a sub and head unit powering 4 speakers. As soon as I started the boat, pp was reading 13.2V and 11.7V with engine off.
Thanks for any help.
amp, ballast, batteries, stereo, system
