  #241
Old 06-20-2013, 08:30 AM
Quinten Quinten is offline
Boat: 1997 Crownline 182 (sold), 2012 Mastercraft X2
Originally Posted by MLA View Post
It could be possible to have 2 loads left running, one on each bank. If your boat has the Dual Circuit Plus switch and a VSR, then the odds are slim that a load on the main bank would also draw down the house bank with the switch left in the on position.
I would 1st determine what rand down the battery(s), then test and recharge the batteries if they test good.
So it's not that 1 battery is just for starting and the other for accesoiry (house battery)?
Old 06-24-2013, 05:45 PM
LTRGUY261 LTRGUY261 is offline
Boat: Centurion, Elite V C4, 2006 5.7L
Sorry to bring life back to this thread, but it seems to be the best I have seen so far. I am a rookie when it comes to this stuff so please excuse me for that. I am going to add a second battery to my boat and am thinking about this kit
http://www.amazon.com/BLUESEA-7650-S...+add+a+battery
Based on my readings, here are my assumptions about this. It essentially works just like the one Diesel mentioned in the original post but also has the on/off switch?
Now my real questions, what else do I need? I have read about fuses and circuit breakers on here. Do I need in-line fuses somewhere? If so where? Could I use this?
http://www.amazon.com/Blue-Sea-Syste...ef=pd_sim_pc_5
How do I know what size fuses to put in for each accessory?
Do I need an additional wire back to the block as a ground for the second battery? What would determine if I need larger wires to the starter from the cranking battery?
Sorry for all the questions folks, but this is the best source of info I have seen on this yet. I will promise to repay your kindness in answering these questions with pictures once I get started and finished with this.
Old 06-24-2013, 07:19 PM
John 3:16-18
Old 06-25-2013, 09:42 AM
Thanks a ton Cloaked! What size fuses at the battery? How do I know what size fuses to put in line and on what components do I need them?
Old 06-25-2013, 09:05 PM
John 3:16-18
Old 06-25-2013, 11:20 PM
SILENTxNOISE's Avatar
SILENTxNOISE SILENTxNOISE is offline
Boat: 2006 Mastercraft X2 MCX w/ 07 Tower
I have a couple questions:
Could someone please explain in detail everything needed for the install of the Blue Sea dual battery switch (sorry if stated in pervious posts -- I haven't read the whole thread)? How many cables will be needed (both positive and negative), how many fuses, and is there any type of "battery install" kit (w/ cable cutters/strippers, terminal ends, etc) that anyone would recommend?
Second, do both the batters have to be the same manufacture if using the Blue Sea switch?
Old 06-26-2013, 10:30 AM
cwoods915 cwoods915 is offline
Boat: '06 X30
Type of Battery
I know there is already the "Official Dual Battery Thread" out there, but it appears that was mainly focused on the dual battery setup rather than the battery type.
Anyways, I want to get opinions on best batteries for the following setup:
2001 Maristar with a Perko switch dual battery setup
Boat features include a 3-channel Kicker amp (http://www.sonicelectronix.com/item_...r-ZX550.3.html) powering 2 polk tower speakers and a 12 inch sub. Boat also has been recently equipped with automatic ballast including 3 Jabsco pumps.
For this setup, what brand/type of batteries would you all recommend (without breaking the bank)? Of course, I've heard the Optima recommendations but wanted to see what else is out there. I've also been suggested running 2 deep cycle/dual purpose batteries but was unsure if this should be done? To wrap it up, the main purpose will be to power the stereo with the engine is off so I'd like batteries that will be able to run down and charge back quickly. Let's hear what you got...
Old 06-26-2013, 11:21 AM
nickespi's Avatar
nickespi nickespi is offline
Boat: 2002 MasterCraft X-30
I'm running two no name deep cycle 27's for my house bank and one Walmart marine non-deep cycle for my starting bank. Less than $300 in all three batteries. Has been sufficient for the last three seasons. The house bank has all accessories, deck, two towers, six cabins, two 12" kickers and two amps that it powers.
Old 06-26-2013, 11:25 AM
I use 80 amp on the batteries and a standard (any automotive store) 10 amp (recommended by the manufacturer's instructions) on the smaller components (the switch on/off purple wire and the head unit). I ran a hot lead from the 2nd battery for the head unit and grounded it to the ground bar in lieu of an accessory ground wire in the boat. I think I used a second terminal block fuse (30 amp IIRC) for the amplifier hot lead (10GA cable) coming off the accessory battery.
So on my start battery I have a terminal block fuse and on the accessory battery I have two terminal block fuses. I used two separate fuses in lieu of the double-stacked fuse block at the accessory battery. Just a preference and I could maneuver the installation easier for the limited room.
You can see one of the in line fuses just below the amplifier in the picture, about middle way on the purple wire. I like that style for ease of viewing the fuse link without a lot of digging and removal of the fuse for checking.
Eliminating the Blue Seas on/off switch will also save you several dollars by not needing the extra cable. Again, the original poster's recommendation will be my next install.
You can also see the 4-lug ground bar just behind the amplifier.
The grey horizontal wires near the top are speaker wires going back out into the cabin. The white vertical wires are going to the head unit pre-amp outs located on the opposite side of the kick panel that everything is mounted.
The purple wires are connected to the ignition switch for the battery relay switch and the amplifier (obviously for on/off operations for each component).
Just below and to the left of the in-line fuse is a red cable and a black cable, each coming from the engine compartment, through the bulkhead wall in the floor, following the route of the steering cable, then I drilled two 3/4" holes in the kick panel to route those two main hot & ground cables into the area in the picture, which is on the port side behind the passenger's seat.
I ordered the one battery box for the accessory battery (around $12 bucks from Amazon) and ditched the cinch straps for the box cover. I replaced those straps with an old life jacket strap that has a clip buckle. Much easier to use when accessing the battery box.
I have seen cleaner installs but I like simple and easily accessible and viewable. Sodar did a nice install among others here...
Thanks again for all of the time spent helping me out. I think I have everything I need on the way for this. Last question can I run a cranking battery as my start and a deep cycle for the house battery?
Old 06-26-2013, 11:41 AM
bturner2's Avatar
bturner2 bturner2 is offline
Here we go again.......
amp, ballast, batteries, stereo, system
