  #201
Old 06-13-2011, 11:37 AM
carlsonwa's Avatar
carlsonwa carlsonwa is offline
Boat: 2006 Prostar 197 TT
battery doctor
I am not sure if anyone else has tried something like this, but I thought it would work great vs. having to remember to flip a switch.....
I have installed this "Battery Doctor" picked it up at Fleet farm, it is an automatic battery isolater, that detects voltage based on the alternator running or not. So it isolates my deep cycle from my starting battery when the boat is off.
http://www.batterymart.com/p-acc-200...-isolator.html
Old 06-13-2011, 01:25 PM
vandit0022's Avatar
vandit0022 vandit0022 is offline
Boat: Mastercraft X-80
Reposted elsewhere.
Old 06-13-2011, 01:58 PM
Does this not require running the isolator to the ignition ??
Old 06-13-2011, 02:04 PM
carlsonwa's Avatar
No ignition input required. It monitors voltage on the main/ or starter battery.
Which rests at about 11.5-12.5 volts when the engine is off and will jump to 13-15 volts when the alternator/ engine are running. Then it connects the 2 batteries in parallel allowing the deep cycle to be charged.
Old 06-13-2011, 02:07 PM
wow. Im getting this.
anyone want a stringer 200amp isolator? I will not be install that as i dont want to take my dash apart.
Old 06-14-2011, 03:02 PM
SWeaver SWeaver is offline
Boat: 2010 X25, 2005 suntracker, 1993 PS205
So, it seems all the previous methods require the same battery types. Would this BattDR need to be the same battery type also? I'd really like to have a deep cycle and a starting battery.
Old 06-15-2011, 09:31 AM
carlsonwa's Avatar
Doesn't say that you cannot have 2 different types. I have a marine starting for main battey and marine deep cycle for aux/ stereo.
Old 07-13-2011, 05:06 PM
scharette's Avatar
scharette scharette is offline
Boat: Mastercraft, Maristar vrs 225, 1995,5.7, X2 2005
yesterday i took my dash apart to locate and connect the purple wire. its an easy task. 2 screws and 3 plastic pins to remove..
2005 X2
Old 07-17-2011, 09:34 AM
scharette's Avatar
i instaled a ss598 Solenoid. The auto part person told me it was the same thing as a Borg Warner R3098.
After 30 minutes of riding, the isolator caught on fire and the ignition breaker went off... We had a lot of smoke coming off the observer seat. Luckily, it dind't do any damage to my elecgtrical system.
can someone confirm the spec of the ss598 solenoid ?
2005 X2
Old 07-17-2011, 11:09 AM
yikes. that sounds like a faulty product or install.
amp, ballast, batteries, stereo, system
