Old 05-24-2010, 01:09 PM
upnthebid upnthebid is offline
Boat: Mastercraft, x-9, 2003, mcx
Zero Flex Flyer Speaker Help?
I have a zero flex flyer tower and need to update the speakers. Any Suggestions on great sounding speakers that will fit in the original Flyer cans?
Old 05-24-2010, 01:12 PM
Here is a picture of the Factory Speaker/Can
Old 05-24-2010, 01:45 PM
nmcjr's Avatar
nmcjr nmcjr is offline
Boat: 2002 X-Star
Bullet makes some 6.5's that I am pretty sure will fit in those cans. I thought about going that route, but ended up just getting the full speaker and can setup so I could upgrade to the 7.7" speakers, which wasn't a whole lot more expensive. You will need a lot of power to go to any of the HLCD setups, but its worth it.
2002 X-Star
http://www.nopowerturns.com
Old 05-24-2010, 02:09 PM
JPK JPK is offline
Boat: X9
I have the exact same cans on my zero flex tower. I replaced mine with 6 3/4" Polk 6051UM. I had to drill and tap out the cans. If you look at the Clarion speakers just outside of the mounting screws there are additional holes. These are where the holes for the Polks line up but the factory cans don't have holes there.
I used a #29 bit with an 8/32 tap (you can use the stock screws) but I replaced mine with stainless allen heads to match the rest of the boat.
Also I had to get creative to mount the tweeters but it was fairly simple. I cut off the back of the mounting (cup) bezels (supplied with the Polk tweeters) and then glued the tweeters to the mounting bezels, then I glued the bezels with tweeters in place. They look and sound great. I found the speakers online for $165/set. I also had the cans powder coated to match.
No pictures but I can get some next time I'm out.
Old 05-24-2010, 05:38 PM
how do the polks sound? I use them for my surround sound in the house.
Old 05-24-2010, 06:43 PM
Don't these require an independent crossover? If so, where did you locate the crossover and did you do any additional wiring?
Old 05-24-2010, 06:58 PM
TayMC197's Avatar
TayMC197 TayMC197 is offline
I have 6x9's on my mini zero flex... They came off a malibu but work great..
Old 05-24-2010, 08:00 PM
bump for nice set up. any major modifications on the install?
Old 05-25-2010, 08:05 AM
TayMC197's Avatar
Not really, I had to make a 1/4 inch spacer to fit between the speakers and tower so that the can faces didn't hit. Wasn't to hard at all. other than that, I through bolted and ran the wires.. not to complicated.
speakers
