Old 06-24-2005, 11:17 AM
Jack's 89 Tri Star Jack's 89 Tri Star is offline
Boat: 2007 ProStar 197
Safety Switch reverse operation?
I have a 89 Tri Star. Launched it the other day, and it would start but as soon as I released the key it would stop. I noticed that when I turn the key on, I was not getting a fuel reading or amp meter reading. When I removed the safety switch lanyard (with the key in the on position), the fuel guage and amp meter came to life. The boat then started as normal. Once running, I put the Safety Switch lanyard back on and the engine stopped running. The Safety Switch is operating exactly opposite as it should! Has anyone ever run into this?
Thanks, so much
Old 06-24-2005, 11:50 AM
LakePirate's Avatar
LakePirate LakePirate is offline
Boat: Tristar 190, 1989 / Maristar 210 2002
Send a message via MSN to LakePirate
Jack, sounds like something is crossed in the dash. Did it run and work ok before? or is this the first time out?
It's Snowing in the UP
Old 06-24-2005, 04:09 PM
I started the boat on land and everything worked normal. The problems started when I launched the boat. The boat worked just fine all last season.
Old 06-27-2005, 10:02 AM
Problem Solved
Well, just as I feared, the boat died this weekend and no matter what postion the safety switch was in, I did not get the fuel guage and amp meter to read. So I had the boat towed back to the lift. I pulled the safety switch out and checked it with my volt-ohm meter. No matter what postion the safety switch was in, I could not see that the switch was ever in the closed position. I cut the switch out and wire-nutted the two leads togheter, now the boat runs again. So what I had was a malfunctioning safety switch. On it way out, it just happened to give me a warning that it was in trouble. I'll order a new safety switch and install it soon.
Thanks
Old 06-27-2005, 11:52 AM
phecksel phecksel is offline
Boat: '03 197
My 88 tristar safety switch acted up too, so I just bypassed the switch. How many people actually use the safety?
Old 06-27-2005, 12:48 PM
stevo137 stevo137 is offline
Boat: none
Some states will call you on it if you don't have one that's working.
Old 06-27-2005, 01:23 PM
erkoehler's Avatar
I always where it when I am out on the river. At our lake in Northern WI, not so much.
www.boathouseh2o.com
