#31
Are you sure yours had any in it. What the purpose of the wad of oiled material is for is beyond me. It's not wax impregnated rope, but a thick piece of felt with oil in in. Probably just disperses a lite amount of oil over time to keep the rotor shaft from corroding to the distributor shaft in case of any moisture and is held in by the clip that holds the rotor shaft to the dist. shaft. IIBW
Charter Member Number 1 Quote: 2RLAKE, At some point in time people need to wake up, remove their cranial intrusion into their own rectal areas, and take responsibility for their own actions. Last edited by TMCNo1; 04-11-2007 at 08:05 AM. |
#32
Even though this thread is some what old the write up is exactly what I was looking for. I will be installing a EI kit om 90' prostar this weekend.
Great write up. Thanks, Prostar Rich |
#33
Excellent instructions. Just made the change this afternoon. Easy to do. While BriEOD suggests it'll take 30 minutes, by my count it was two Miller Lite's.
Rough idle gone. Hole shot seems a little better, but that was without a skier and might be my imagination. Bongo |
#34
Charter Member Number 1 Quote: 2RLAKE, At some point in time people need to wake up, remove their cranial intrusion into their own rectal areas, and take responsibility for their own actions. |
#35
Holy crap I can't wait to do this to mine
How much is an EI kit?
boats rock, but don't rock the boat |
#36
How did I miss this post...
![]() What a great pictorial and "How To" on electronic ignition conversion BriEOD. Step by step instructions with pictures, can't get much easier than this...we need more of this kind of info and documentation here on TT Looks like some much fun I am gonna redo mine tomorrow.... Thanks
If for some reason you start to believe you are a person with influence, just try ordering somebody else's dog around. |
#37
http://www.mastercraft.com/photopost...er=2572&sort=1 Need LT-1 parts? OIL FILTER: Factory installed is a Penzoil P23, Afta market brands, AC Delco PF-454 and a Fram PH-13 or PH-30 will work. SPARK PLUGS: AC Delco MR43LTS (gapped to .040") FUEL FILTERS: AC Delco 25171391 (pump inlet side) 89058397 (pump outlet side) IGNITION WIRES: Call Inboard Online @ (877) 327-7175 and order part numbers 556010A (odd bank) and 556010B (even bank) |
#38
Here is an example, http://www.skidim.com/products.asp?dept=1113
#39
I'm going back a few years, but don't most EI ignitions use higher voltage coils? (EI Ford and Mopar) Can't count GM HEI, that's got 40K volts.
I would think performance would be better with that "EI" coil that skidim sells.
I was njskier on here. |
#40
No problem gents, I'm happy to help. I'm glad I could provide something useful to the board. I'm waiting for Eastie to provide his step-by-step instructions, with photos, of how to barefoot long line.
