Old 05-05-2010, 09:24 AM
dlboltond dlboltond is offline
Boat: 1992 Mastercraft Maristar 210
Exclamation Tranny fluid change question
I have a 1992 Maristar 210 with the velvet 1:1 transmission. Bought it end of the season last year and am trying to catch up on maintenance. I went to look at the transmission fluid and this is what I found.Name:  IMG_0485.jpg
The picture makes it look a little darker than it really is. My question is what can I put back in the transmission? I can't tell if this is motor oil or transmission fluid or does that even matter? Can 15w40 be used in the direct drive transmissions? I can not see any trace of red.
My plan is to change it 2-3 times this season until it cleans up.
Thanks
D
Old 05-05-2010, 09:44 AM
Jorski Jorski is offline
Boat: 1993 190 with LT1
That sure looks like motor oil. There was period of time where 15w-40 was recommended.
I think ATF fluid makes more sense but either will do...check the manual. FWIW, I have a 1993 1:1 velvet drive with ATF in it and it works great.
Old 05-05-2010, 09:48 AM
That is what I thought. The manual says Dexron II, but I didnt know if there would be a problem with mixing if I got it wrong.
Old 05-05-2010, 10:17 AM
Also, is there a problem with putting new fluid in? Just wondering about the old story about old transmission fluid is better left unchanged.
Old 05-05-2010, 10:25 AM
There wouldn't be a problem with the residual oil mixing with the new transmission fluid. If it were me, I would change it, run it, change it again and run it again; and so on, until the fluid was clear and red.
Good luck!
Old 05-05-2010, 10:27 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
You want to use Dexron/Mercon in your Velvet Drive 1:1. The motor oil recommendation was for gear reduction transmissions on models within the last ten years. Change it a couple of times if you suspect there is motor oil. In this application, it is not better left unchanged.
Previous: 1993 Prostar 205
FAQ
Tyler Ski Club
Old 05-05-2010, 10:29 AM
Thanks guys. I will change it with the recommended Dexron II multiple times until it looks better.
D
Old 05-05-2010, 10:38 AM
D
It'll be Dexron III or IV at this point. Dexron II is no longer available.
FAQ
Tyler Ski Club
Old 05-05-2010, 10:40 AM
Good to know. Does it make any difference if it is III or IV?
Old 05-05-2010, 10:43 AM
No difference of which I'm aware. Just the latest incarnation. Either will be fine.
FAQ
Tyler Ski Club
change, oil, transmission
