Old 05-02-2010, 02:08 AM
davomaddo's Avatar
davomaddo davomaddo is offline
Boat: MasterCraft, X-15, Salt Water, 2009
Blue Sea Battery Switch
I searched but couldn't find this. It should be simple.
I have an 09 X-15. It has 2 batteries and a blue seas switch.
There are 3 modes, off, on, and combine.
My old boat had, 1, 2, and both.
What is the difference between on and combine and when do I use combine?
Question 2.
When I am charging the batteries, what mode do I use?
Question 3.
Do I charge each batter seperately, or will hooking a charger to one charge both?
Thanks
Old 05-03-2010, 03:17 PM
davomaddo's Avatar
Can anyone help?
I figured this would be an easy one...
Old 05-03-2010, 04:09 PM
Shaun315's Avatar
Shaun315 Shaun315 is offline
Boat: Mastercraft
Combine when your starter battery is dead to allow the house battery to help start the boat.
Question 2.
Probably doesn't matter, likely leave it ON, connect charger to the battery the alternator connects to. Should be able to charge both if they are similar/same batteries. If different types of batteries, I'd charge individually with the switch in the OFF position.
Question 3.
Thanks
See above.
Old 05-04-2010, 10:22 AM
davomaddo's Avatar
Thanks for the help.
