Backing up inclines
Wondering if anyone has come up with a good idea on how to back the trailer up an incline without scraping? I would like to store our boat in our garage, but do not want to hear metal grinding going up the driveway.
Depending on what type of hitch you have, you could try using a hitch that drops the ball down lower to get the back end of the trailer a little higher.
Tim South Florida Mastercraft |
The newer trailers have steel rollers under the prop guard. Alot of people have retrofitted rollers to the older trailers.
Cheaper suggestion, can you get a drop hitch that lowers the front of the trailer way down? Might get the back up enough to clear your driveway approach.
'06 X2 MCX "I understand why some people may not want to do this the way I have recommended but I can't understand the death grip some people have on a toilet plunger with a hose fitting." -JimN |
Mine scrapes every time, just have to get used to it and go easy. Can't be anal about the concrete either it marks it pretty good.
___________________________________________ ________________________________ |
You can also try placing some wood planks under the tires to help lessen the "drop" area if you have a low spot at the end of you driveway. Rollback drivers do this all the time when loading corvettes and other low cars.
I was njskier on here. |
I'm sure you wouldn't ask if hitting at an angle was possible?...atv?
#7
I also have a short distance of contact, and have used the planks. However, I put them between the prop guard and the concrete. The scrapes are a little bit muffled, and no marks in the concrete.
2006 X-45 LQ9 2005 Yukon Denali |
#8
I've come to like the scratches, the more there are, the more I've been out on my boat.
#9
http://weathersticker.wunderground.c.../Brunswick.gif |
