Spark plug wires
does anyone know on a boat how long do there plugs wires last...i have a 2000 x star with the LTR and i know that they r at lest 4 to 5 seasons old..it has a little over 600 hours on it and the wires do look good..it has 8mm talor wires on it so i don't know if that is factory or someone else put them on?????
I replace mine every other season. That's probably overkill though.
Lots of power is good, more is better, too much is just right. ![]() '91 prostar 190 |
I installed a set of Accel 8mm wires on our '89 18 years ago and they are still on there! I don't see changing them anytime soon. My mechanic did a test on them 4 years ago while doing some ignition work and said they were good to go for several more years.
I suppose it depends on the number of hours you put on, but my '92 had the original wires on it for all 14 years I owned it, and never had an ignition issue. My '04 still has the originals in it now and I have no plans to replace them any time soon.
Steve
A positive attitude may not solve all your problems, but it will annoy enough people to make it worthwhile 2004 Prostar 197 - Red on White 350 TBI, Perfect Pass, Heater, Shower and a whole lot of fun! |
seams like they last a long time if you take care of your boat..thanks guys
Anyone know the current plug wire part number for a 1999 LTR motor with the northstar distributorless ignition? Current wires are Packard Electric Marine which I believe was bought by delphi.
Others said they have Taylor but no mention of part number. Contacted skidim but the special order price was a bit high. Might consider making a custom set. Thanks
New Boat - 1999 205 Blue/White LTR, Monster Tower Old Boat - Red/White 1991 PS190, Tower, 351w & Powerslot |
14yrs and 500hrs on my PS 190 wires, still ran like a top last fall when I sold it.
for the older boats they're cheap ($28), so i dont have a problem with replacing every couple years.
You can test wires for the amount of ohms present. But you would have to find the wires "resistance" to see if they are worn out. I like to look at the wires at night and see if there is a light show
1981 MasterCraft 19' Skier 351W PowerSlot Deluxe Long gone is the Trans AM
