Old 04-12-2010, 11:32 PM
simonmathews
Aluminum honeycomb floor panel Mastercraft Prostar 190
Hi - don't know if anybody can help me. I have a 1996 Prostar 190 and am having the interior replaced. Where the engine cover mounts to the floor panel has been damaged and I am wondering if anybody knows who makes the panel itself? Is it possibly made by Bellcomb? Thanks!
Old 04-12-2010, 11:48 PM
east tx skier's Avatar
Boat: 1998 Ski Nautique
The problem was the washers used were not large enough. I put a wood stripe across that section of the floor to spread the load. Drilled new holes and used longer bolts. Worked like a charm. HDPE would work as well if you have issues with the whole wood in a boat thing (understandable).
Previous: 1993 Prostar 205
FAQ
Tyler Ski Club
Old 04-13-2010, 12:05 AM
simonmathews
Thanks for your response - a new section was added to support the hinges, but it is still badly damaged. Looking for a new panel.
Old 04-13-2010, 06:48 AM
H20skeefreek's Avatar
H20skeefreek H20skeefreek is offline
Boat: '85 Stars and Stripes
Can you just flip it around?
ITCHIN' TO SKI, LET'S GO!!
1985 MasterCraft Skier, Stars and Stripes
351W with PowerSlot and Perfect Pass
Click here if you need prayer, or wish to pray for those who do.
Old 04-13-2010, 08:59 AM
03 35th Anniversary's Avatar
03 35th Anniversary 03 35th Anniversary is offline
Boat: 2003 35th Anniversary LQ9 Supercharged
I did this samething to the 93 190 that we are restoring. Except I used a piece of 1/4" alum. plate.
Old 04-13-2010, 10:28 AM
Jorski Jorski is offline
Boat: 1993 190 with LT1
That's exactly what I did to mine...it has held up fine for over 5 years that way.
Old 04-13-2010, 09:32 PM
ccelia ccelia is online now
Boat: 1989 Mastercraft Prostar 190
I just replaced the entire panel with 3/4" pressure treated plywood. After putting a few coats of fiberglass and a few coats of resin on the plywood, it is just as smooth as the original and fits perfectly and is very solid. Cost was about $55 dollars total as I had to buy a full sheet of plywood.
I can't comment on how long its going to last but I would guess that it will last a while as it is completed glassed in.
Old 04-26-2010, 01:13 PM
Dylan's Avatar
Dylan Dylan is offline
Boat: 1995 Barefoot 200- Yamaha Pro-v
Sorry to hijack your thread, but I have a similar situation in my BF200. The aluminum floor panel makes a slight aluminum foil sound when stepped on, and has a little give that I'm not too happy about. I took the panel out, and it seems that the bottom aluminum piece has separated from the honeycomb area. Was it ever determined where to buy a new sheet? I looked into replacing it with wood, but the section on my boat is 1" thick. That would make a ton of additional weight vs. the aluminum. Any thoughts?
Thanks!
Old 04-26-2010, 05:48 PM
Well, you could probably go with 3/4" and put 1/4" strips on each edges...
Old 02-08-2013, 05:35 PM
93LT-1 93LT-1 is offline
Boat: Mastercraft,Prostar190,1993,LT-1
Panel replacement
Hi, I replaced my aluminum panel with a 1" plastic panel. Its heavier but will not rot. I was able to remove the carpeting and replace it on the new panel. the panel was about $65
