rpm problem
Hi guys
I have and old 1994 maristar 225vrs with a little problem. Tach (rpm) is not working well it says less rpm than what you are running and when you blow the horn the tach goes up it was working fine but not any more any ideas???? Thanks for your help |
I would start with the all the connections including the fuse. I had to deal with a bunch of light corrosion when I got my boat and t made the electronics do all sorts of weird things.
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com SPECIAL PRICING CONTINUES Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. |
Bad ground at the dash or as stated, bad connections.
Thanks a lot guys i will check it right now and let you know if it worked
| Tags |
| gauges, rpm, tachometer |
