Old 04-09-2010, 02:15 PM
76S&S's Avatar
76S&S 76S&S is offline
Boat: 2002 X Star
Shaft seal (rope stuffing)
I've replaced the rope stuffing on the shaft before on a DD, but how in the world do you get to it, to replace it on a V-drive.
Not even my 100 lb, 5'7" son can seem to get his hands in there to do this.
2002 X Star
Sold - 76 S&S
Old 04-09-2010, 02:24 PM
Boat: 1998 Maristar 200VRS
Options:
1. Don't replace it. Instead, buy a reliable bilge pump or two.
2. Pay the dealer to do it.
I've done it on mine, and it was a PITA. Might be a bit tighter on yours.
/frank
Old 04-09-2010, 02:58 PM
76S&S's Avatar
Boat: 2002 X Star
I've been leaving the bilge on auto, so every other time (or so) we take off, it kicks on when the water rushes to the rear.
I agree, it is a PITA!!!!!
2002 X Star
Sold - 76 S&S
Old 04-09-2010, 11:46 PM
You may want to try simply tightening up the packing nut.
Of course, on my boat, that's 90% of the PITA of replacing the packing.
/frank
Old 04-10-2010, 10:22 AM
MariStar-Man's Avatar
Boat: 1999 Maristar 210 VRS
Shaft Packing for me was pretty simple. I used a shaft removal tool then slid the shaft about 2' and Removed the Packing Nut.
Then while sitting in the shade and with a razor blade, cut the packing at an 45 degree angle so it would overlap the Diameter of the shaft. It requires 3 rings of packing with the cut staggered so the cuts don't line up.
Reinstalled the nut, put back together, and took to lake. Checked drip rate and tightened the nut accordingly...
good luck
1999 MasterCraft Maristar, V210, 330 Hp LTR
Mods: Upgraded Stereo, Amp, 6 Disk Changer, Zero-Flex Tower, Custom Fit Bimini Top, and of course...Teak Oil!
Old 04-12-2010, 09:33 AM
76S&S's Avatar
Boat: 2002 X Star
MS-Man, I'm not following you, I can't even get my hands in there to work on this???
2002 X Star
Sold - 76 S&S
Old 04-12-2010, 05:54 PM
First of course one has to put the side boards of Engine compartment flat.
Then Loosten Larges Nut next to Gas Tank on a V-Drive, and 4 stainless bolts.
Remove propeller
Loosen, packing nut
Using Shaft Removal tool. Slide shaft back about 2' remove Packing nut. Make sure you buy either ROPE or better GORTEK shaft rope. Different lengths for 1" shaft and 1-1/8th" shaft
Follow following proceedure
http://mastercraft.com/teamtalk/show...0&postcount=31
Old 04-12-2010, 05:57 PM
Boat: No Boat
Why would you need to remove the prop to change the packing? I don't have a Vdrive so I don't know.
Tim
Old 04-12-2010, 06:56 PM
Chicago190's Avatar
Chicago190 Chicago190 is offline
Boat: Mastercraft, Prostar 190, 1996, 285 HP
He's suggesting that on a v-drive the packing nut should be completely removed from the shaft, which makes it easier to remove the old stuffing rope and repack the nut. However, removing the shaft coupling and prop is a lot of work, and still requires quite a bit of dexterity on v-drives. There are still some benefits to having that big motor box in the middle of the boat.
1996 Prostar 190, 350 TBI and Powerslot
