Old 08-19-2004, 09:30 AM
etduc's Avatar
etduc etduc is offline
Boat: Something else, DD 2004 red/white/black
1990 Tristar gas tank
New to the forum. New to inboards. I have an old Tristar, that I'm refurbishing.
How many gallons, does the stock gas tank hold? The boat has had multiple owners, last owner didn't know, if tank had been changed.
The tank, currently in the boat, is plastic and doesn't have any internal
baffles. So fuel moves around, quiet a bit. Plus, fuel guage never reads correctly (haven't pulled the fuel float, yet.)
I haven't drained my tank, and refilled, to determined its capacity.
Just needing, specs, before I pull the tank.
Nice site. Been lurking on it, awhile.
ET
Old 08-19-2004, 09:35 AM
MarkP's Avatar
MarkP MarkP is offline
etduc
Um, I dont know
Old 08-19-2004, 10:21 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
A lot of the early 90s boats eventually have problems with the fuel sending units. I've heard of people fixing them and I've heard of people replacing them. Just depends on what your comfort level with doing that is. Since I'm not terribly mechanical, I opted to replace mine. The slosh is typical if my 93 Prostar is a good example.
Not sure what the fuel capacity of the tank was on the 90 Tristar. My manual says I have a 30 gallon tank, but I've heard people say that they aren't getting near the reported capacity. Surely someone with a 1990 boat will have his manual and give you the specs though.
Welcome to the board.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 08-19-2004, 10:40 AM
jwchapman jwchapman is offline
Boat: 1988 TriStar 190
88 TriStar 190 Gas Tank
My 1988 TriStar 190 has a 25 gallon tank. The tank is under the floor in front of the engine and drain plug. If yours is there I would bet it is the same.
If you have the TriStar 220 however, it is listed as 34 gallons for the 1988. These amounts are listed in the 1988 Brouchure which is posted in the Downloads section above.
Old 08-19-2004, 01:46 PM
Hoff1's Avatar
Hoff1 Hoff1 is offline
Boat: MasterCraft, Maristar 210 openbow, 1990, 351W
I have a 1990 Maristar 210. Tank is behind the rear bench. It has a 40 gallon capacity. I found this out two ways. First way, ran out of gas because @#$% gage didnít work. Filled tank. Second way, pulled back bench seat, fiberglass, and floor panels out. Tank had a sticker that said 40 gallons.
I opted to replace send unit for about $25. Took only a few minutes. I couldnít find one that was the correct depth. Gas gage reads empty when I still have about 15 gallons. I like to consider this my reserve.
Old 08-19-2004, 02:17 PM
Wow! 15 gallons is a heck of a reserve. My new sending unit ran me about $70.
FAQ
Be kind. Have fun.
Old 08-19-2004, 03:33 PM
etduc's Avatar
Something must be running on the company server, preventing the
downloads from working.
25 gallons is about right. Slosh would be more of an issure, if there's an oversized tank. (Submerging the front, with passengers)
Working on fuel sender, is a piece of cake. I need to pull it, and inspect inside of tank anyway.
This boat makes a bigger wake, than I'd expected. Flattens out at
pretty good at 34. Hull needs major resurfacing. Sonar sender on outside of hull, and some kind of housing over raw water intake. Creating major drag. Which maybe, contributing to wake issues.
Anyway, it's rainy, in East Texas. Gotta get back to work.
ETduc
Old 08-19-2004, 08:18 PM
phecksel phecksel is offline
Boat: '03 197
Tri-Star was not known for it's wake. It's very sensitive to weight, so keep it light. You will never get the gas gauge to work well. I finally was happy with an accurate reading while idling in neutral. It was a very good boat to me for several years. Hated it from day one, but never had a reason to get rid of it.
Tri-Stars hidden feature, place a 2x4 cross beam in the cutouts and rest the seat on it. Add rear supports and something to keep the seat from sliding forward, wahlah, bikini platform
Old 08-20-2004, 11:03 AM
Man, I gotta start paying more attention. Where in East TX?
FAQ
Be kind. Have fun.
Old 08-20-2004, 01:46 PM
etduc's Avatar
Longview,tx
