I've always wanted a Mastercraft and just bought my first!!!! A 1991 Prostar 190. I was told it had a Chevy 350, but I'm inclined to believe that it is a Ford 351. How do I know for sure?? Did Mastercraft put Chevy engines in 1991 Prostars?? Everything I am finding online lean toward Ford 351's.
They switched to Chevy's in 1994, some 93's had the LT1 Chevy as an option.
OH-IO! |
You most likely have a Ford.
http://www.mastercraft.com/knowledge/owners_manuals Here is a link for some manuals on your boat.
“Normal is Broke, Be Weird.” |
Distributor at the front of the motor is ford 351. If it does not have a carb then someone has swapped the motor along the way. My 93 205 had a 351, carbed. My 95 has a LT1 fuel injected, says corvette on top, Love it.
thanks guys, the dist. is in the front. I kinda figured so. now I can go forward with ordering misc. parts. Ski on!!!!!!
FORD 351 dist is in FRONT by THERMOSTAT HOUSING CHEVY Dist is in back behind Air Cleaner Possible a Checy but more than likely a FORD Chevy was an options Jim@BAWS
Tampa Bay's Exclusive MasterCraft Dealer www.BAYAREAWATERSPORTS.com (813) 996-BAWS (2297) |
#7
Chevy valve covers bolt through the top of the cover and down the middle of the valve cover. Ford valve covers bolt on the flange around the outside of the cover.
1987 TriStar 190 Red & White Ski Yesterday, Ski Today, Ski Tomorrow |
#8
What you got there is a "boat motor".
![]() If the distributor is in front, it is a Ford. In back, it is a Chevy.
1995 Mastercraft Prostar Slalom Fanatic I was told there would be no math?
#9
Yep, the original brochure I've seen for my '89 referenced the 350 as an option. 10-20 more HP over the 351 I think. Can't remember the upcharge for the 350, but I think I've seen it on here somewhere. Out of curiosity, does anyone have a guess as to the approximate number of first generation pro-stars that had a Chev 350? Were the S&S available with a 350? Anyone ever been in one of each on the same day? Just curious on the differences in sound, hole shot, top speed, etc. I'd expect it to not be much different, just curious.
Kevin
1989 ProStar 190 with "Safe T Top", 351 Ford, Elec. Ign, 1:1, 720 hours, 4 blade prop, PP 6.5, removable platform brackets, custom color from factory, hot water shower, Boat Buddy & LED lights on trailer 2008 D3 Nomad RCX, 4 @ 28 off, 34 mph so far |
#10
I have ridden/skied/drove a '84 19 Skier and a '88 Platinum ProStar with the 350 and there wasn't that much difference if any. The only reason the owner had the 350's was he hated Fords and wouldn't have anything else and had the $ at one time to buy the boats at the boat shows and had them sent back to the factory to be swapped out. |
