Old 03-10-2010, 07:45 PM
wattsbarx2's Avatar
wattsbarx2 wattsbarx2 is offline
creamy tranny oil
Anybody had their tranny oil look creamy(milky) before? I've used penzoil in some of my vehicles before and had the same result. hopefully that's all it is.
Old 03-10-2010, 07:54 PM
Location: .......................................out selling tires
Happy to say welcome to Team Talk, but sorry to tell you you have water in the fluid.
1977 Stars & Stripes
- Peter
People are bastard-coated bastards with bastard filling. Dr. Perry Cox - Scrubs
A man has to know his limitations. Dirty Harry
Nothing tighter than a good cross-thread. thatsmrmastercraft
tiresplease@gmail.com
Wholesale Tire Sales
Old 03-10-2010, 08:53 PM
njskier's Avatar
njskier njskier is offline
Trans cooler might be cracked allowing water to enter your trans.
I'd remove it and have it pressure tested, and for sure change your fluid.
2005 X-star MCX (black & white)
2007 Yukon XL Denali (tow vehicle)
Old 03-10-2010, 09:09 PM
ttu's Avatar
ttu ttu is offline
you really need to give us a whole lot more details.
i have a 07 x2 and the wonderful "j" hose cooling line split in my boat at around 40 hrs. did not notice untill the bilge pumps were working overtime. come to find out the water got above the trans and water got into the system. dealer took care of it and was told they would warranty the tranny 3 more years.
Old 03-10-2010, 10:08 PM
Chicago190's Avatar
Chicago190 Chicago190 is offline
Obviously, change the trans fluid before using the boat again.
The way I see it, the following things could be the problem:
1. Nothing. Water may have gotten in through an accident, like the bilge filling with water during a rain storm when battery was disconnected.
2. Cracked trans cooler. It is possible that there was some water in it when the boat was winterized, and the water froze and caused a crack. As noted by NJ, take it off and have it pressure checked.
3. Trans seal needs to be replaced. This is an occasional issue that has come up. Run a search for "transmission seal" and you'll have all the info you need.
4. There is a service bulletin about a faulty transmission breather vents. Maybe call your MC dealer and see if they are aware of it, and whether it applies to your boat.
1996 Prostar 190, 350 TBI and Powerslot
Old 03-10-2010, 10:12 PM
03 35th Anniversary's Avatar
03 35th Anniversary 03 35th Anniversary is offline
Look kinda like this?
Old 03-11-2010, 01:03 AM
MariStar-Man's Avatar
Mine looked like this. I still don't know if it was "Normal..." Is your's similar, thicker?
Oh and welcome to TT. Did you get a chance to rake some pix? What kind of boat do ya have?
1999 MasterCraft Maristar, V210, 330 Hp LTR
Mods: Upgraded Stereo, Amp, 6 Disk Changer, Zero-Flex Tower, Custom Fit Bimini Top, and of course...Teak Oil!
Old 03-11-2010, 04:43 AM
wattsbarx2's Avatar
Its an 07 X2 which uses the 15w40 in the transmission which to me is weird puttin motor oil in a transmission.
Old 03-11-2010, 07:37 AM
bigmac bigmac is offline
It's a pretty simple transmission, most notably it doesn't have a torque converter, so the oil used isn't that important. Indmar/ZF Hurth used to recommend ATF, but in about 2001 they started getting complaints of rattling at idle so Indmar, with Hurth's blessing, switched to recommending 15W40 in their gear-reduction transmissions. I'm sure a wide variety of viscosities would work, but for convenience they picked the same stuff that goes in the engine.
Maristar-Man, your ATF looks like it has some water in it too.
'04 MariStar 230VRS/MCX
Old 03-11-2010, 08:05 AM
coz's Avatar
coz coz is offline
Originally Posted by bigmac View Post
Maristar-Man, you're ATF looks like it has some water in it too.
Sure does, should look like this not pink.
