  #51
Old 06-23-2010, 04:56 PM
barefootjoe barefootjoe is offline
Boat: 1980 stars n stripes Orig 351 pcm engine ++
I put on two wraps overlapped on opposite sides, tightened, then wiggled the steering arm, tighten wiggle, and so on. I pulled the nut off and The Graphite eventually formed a nice 1/2 inch wide smooth edge around the shaft. , and I cant get the nut any tighter, using a large box wrench. Rudder still turns nice and smooth so I think its good to go. There is still about 1/2 inch of threads left to go down if it needed tightened later, but I am hoping not because there is no access without pulling the gas tank.
Who reads posts? I just look at the pictures.
Old 06-23-2010, 09:35 PM
Finished the back end today, Tommorow, On to the engine!
Tank is in place and all hooked up.
Old 06-23-2010, 09:38 PM
Permant repair! No Leaks allowed after the gas tank is in place.
Old 06-25-2010, 11:37 AM
working on the fuel pump and water pump today. Are there any special tricks to priming the fuel pump, or will this work automatically? The entire fuel system is new - dry including tank, line, pump, carb.
Also, this had an electric pump on it which I removed, where should the fuel filter go? Before on the input or output side of the mechanical fuel pump?
Old 06-25-2010, 10:48 PM
Fuel pump is in and working, Solonoid replaced, She lives and breathes again!
Time for a test run!!!!
Old 06-25-2010, 10:57 PM
americanskierJim's Avatar
americanskierJim americanskierJim is offline
Boat: 1980 Mastercraft S&S Powerslot, 351 Windsor
Send a message via AIM to americanskierJim
Barefootjoe, Good luck with your test run post some pics.
Old 06-26-2010, 04:16 PM
Finally have the bilge running, hoping for an early morning run tommorw. One more thing to do. Please help...Post picture if possible
Where is the drain plug located on the transmission? velvet drive 1:1?????
Old 06-26-2010, 04:38 PM
JLeuck64's Avatar
JLeuck64 JLeuck64 is offline
Boat: 98 Prostar 190 Stars & Stripes, LT1
No drain plug on those... need a fluid extractor to pull out the old fluid. You can get most of it out with one of those.
Need LT-1 parts?
89058397 (pump outlet side)
Old 06-26-2010, 06:52 PM
that is what I thought, improvized and used a long clear hose and syphened most of it out.
Thanks, tomorrow I am off for the first test ride!
Old 06-26-2010, 08:03 PM
Cloaked Cloaked is offline
Boat: MasterCraft
Inexpensive drill pumps work well.
1980, barefoot, fuel pump, propeller, stars & stripes
