  #41
Old 04-14-2010, 07:21 AM
barefootjoe barefootjoe is offline
Boat: 1980 stars n stripes Orig 351 pcm engine ++
Two more back of the boat questions:
1. Where is the bilge supposed to be located? Mine is in front of the engine.
2. Where is the blower normally located?
Thanks!
Old 04-14-2010, 07:32 AM
1redTA's Avatar
1redTA 1redTA is offline
Thanks!
1 on my 81 the bilge pump is under the crank pulley
2 the blower is under the rear deck above the gas tank held into place by a rubber U
1981 MasterCraft
19' Skier 351W PowerSlot
Old 04-14-2010, 09:11 AM
amber 6's Avatar
amber 6 amber 6 is offline
Boat: 82 Stars and stripes
On my 82 Stars and Stripes bilge pump is same but blower is in the front and blows through and out the back?
Old 04-15-2010, 02:50 AM
Another post was talking about blowing in from the front intake to get more cold air to the engine when running providing more power, Just like the cold air intake on my car....
Because I am moving the blower anyway, What do you think is better, Blowing fresh air in from the front or sucking the fumes out from the back.
Who reads posts? I just look at the pictures.
Old 04-15-2010, 08:44 AM
Miss Rita's Avatar
Blowing fresh air in won't necessarily get rid of the fumes in the bilge; the priority should be to exhaust the stale air first. As that air is pulled out fresh air is pulled in. It would be interesting to see what, if anything, would happen to engine performance if you could lower the intake air temp any significant amount.
Would it make sense to have both an exhaust fan and an intake fan? How about two exhaust fans? Interesting concept. My gut feeling is that it wouldn't make an appreciable difference.
Old 05-05-2010, 08:48 AM
79_SnS_atl's Avatar
79_SnS_atl 79_SnS_atl is offline
Boat: 1979 Stars and Stripes / 351 PCM
I agree with Rita, to have any appreciable difference you would need to intercool the air coming in to the intake (if you figure out how to do that in a MC let me know!!) However the push pull method of having two fans would not be a bad idea if the cost of the fans was not out of reach.
Find more info on my latest project on FaceBook: http://www.facebook.com/group.php?gid=102832819752389
"Keeping the dream alive."
Old 06-23-2010, 02:34 PM
I am finally back at it after a two month break for knee surgery.
Working on the back end, Reinforced the transom, remounted the swim platform, New speedo lines and pickups, Gas tank emptied and cleaned, new flanges welded on, New rear exhaust lines, New blower,
Question on the steering head; I recieved some graphite packing from skidim, but it seems too small, when placed in the nut, there is a 1/16th inch gap between the packing and the steering shaft. Am I supposed to compress it until it squishes wide enough? or ? Also, how many rings should I use? I have two in the nut currently.
Old 06-23-2010, 03:02 PM
M-Funf's Avatar
M-Funf M-Funf is offline
Boat: 1976 Mastercraft Stars & Stripes 351W
barefootjoe,
Did you leave the stabilizer tubes in? I had a leak in one of mine, so I bypassed it. Works just fine without it. Needle doesn't bounce much at all.
M-Funf (a.k.a. Jeff)
Our '76 Stars & Stripes
Canis meus id comedit
Old 06-23-2010, 03:05 PM
replaced one side, covered ends of other side with marine sylicone sealent by 3m, becomes rock hard after 7 days. Same stuff I used to help lock the swim platform, in addition to the bolts. Anny suggestions on the steering packing?
Old 06-23-2010, 03:19 PM
On the SKIDIM site they call for three wraps. Sounds like you might be using the wrong size. I believe there are two sizes. Which size did you get?
1980, barefoot, fuel pump, propeller, stars & stripes
