#31
Barefootjoe,
Do you have any pics of the transom looking from the engine area aft? I'm about to fix my swim platform and/or remove it and I'm really curious to see what it looks like / what bolts / lag screws go into... I posted a few questions here http://mastercraft.com/teamtalk/showthread.php?t=33234 if you're interested. Thanks! |
#32
Someone has put the shadetree knee grow mojo on that boat. It's not a lost cause but you have some work to do to get it back to a state of somewhat original.
If you pull the exhaust hoses at the manifolds, be prepared to struggle to get the new ones back into place. If the current ones are good, leave them be for now and work on the transom. Don't ask how I know... You'll need a blower too. Do not use the boat without proper (and required) ventilation.
93 190 . Hypocrites, boot lickers, and crybabies…the world is full of them…. just look around - near-by . Duraflap / Kaydenco aren't worth a hoot Hose picture (internal) http://www.mastercraft.com/teamtalk/...68&postcount=8 . |
#33
93 190 . Hypocrites, boot lickers, and crybabies…the world is full of them…. just look around - near-by . Duraflap / Kaydenco aren't worth a hoot Hose picture (internal) http://www.mastercraft.com/teamtalk/...68&postcount=8 . Last edited by Cloaked; 04-12-2010 at 10:25 PM. |
#34
Yes and correct. Also replace the older pitot tubes with the newer pickups. They do not collect trash near as much.
#35
Thanks for all the input, so more to add to the to do list.
Im going to try 6 inch ledger lockers where the lag bolts were and see if I can hit some solid stringers to grab. Will let you know on the results. I am also having plates made up for the inside/bolts simular to the pic you posted. Yes, blower, I forgot all about that. When I was a kid in WI I watched a stars and stripes blow up. It launched the two kids sitting on the engine box right out of the boat and then burned to the water line. Everyone got out safe thankfully. Where is the blower normally located and where should I look for the electric leads? |
#36
The blower on my '77 is above the fuel tank. Pretty much have to be a contortionist to do anything with it unless you pull the tank ahead.
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com WHEEL SPECIAL Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. Spare tires too. |
#37
Yes, this makes changing the oil MUCH easier, keep that there and flush it. I recommend putting a gate valve just after the line from the oil pan so you have redundancy if the plug a the stern comes out accidentally.
Find more info on my latest project on FaceBook: http://www.facebook.com/group.php?gid=102832819752389 "Keeping the dream alive." |
#38
Call Donnie Bennett at Bennett Boat Works. He more than likely has a replacement , he bought all of MasterCrafts old parts. 865-982-9589. If he does not have it then Rambo marine In AL could have what you need also www.rambomarine.com
#39
Check out my resto project of my '79 SNS http://www.facebook.com/group.php?v=...02832819752389
#40
| Tags |
| 1980, barefoot, fuel pump, propeller, stars & stripes |
