Old 04-03-2010, 10:16 AM
woobiedmd's Avatar
woobiedmd woobiedmd is offline
Boat: mastercraft PS190 1988 351
Question Water Leaking from shaft seal
I pulled my '88 Prostar out of the garage and de-winterized it. The engine fired right up with the garden hose attached. However, water is coming out the bottom of the boat where the shaft exits. There is no water in the bilge. Is this normal? I am worried about going to the lake and having a problem. Any thoughts?
Mark
Old 04-03-2010, 10:32 AM
CantRepeat's Avatar
Boat: No Boat
Mark
Are you running a dripless shaft kit? If so, could it be the water coming from the line into the dripless system running out of the back of the shaft onto the ground?
I'm not sure if this is how the dripless systems work as I don't have one.
Like this one.
Tim
Old 04-03-2010, 10:58 AM
Skipper
Guest
Posts: n/a
If there is no water in the bilge, then the water must be getting pumped into the shaft to a dripless seal.
Old 04-03-2010, 01:40 PM
woobiedmd's Avatar
Thanks, I do know the previous owner had installed such a set-up!
Mark
Old 04-03-2010, 01:55 PM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Mark
Yup, freaked me out the first time I fired the X2 in the driveway. Never been around a dripless setup before and didn't know there was a source running to it from in the boat, thought it picked up water directly from the lake or something until I started poking around.
'06 X2 MCX
Old 04-04-2010, 11:10 AM
carracer's Avatar
carracer carracer is offline
Boat: MasterCraft 2008 X30
X-30 Question
Why does water run out the shaft seal, my dealer said not to worry that it was perfectly fine. My question is if water can run out why not in? I never saw this issue with my prostar.
Old 04-04-2010, 11:12 AM
Sodar's Avatar
Sodar Sodar is online now
Boat: '07 ProStar 197 w/ MCX
Your old boat most likely did not have a dripless shaft seal. The new boats use water to lubricate the dripless seal. If you yank the floor out and look, the shaft seal has a water line running to it. Everything is normal.
-Cameron
2007 ProStar 197
1996 ProStar 190
Old 04-04-2010, 11:26 AM
Chicago190's Avatar
Chicago190 Chicago190 is offline
Boat: Mastercraft, Prostar 190, 1996, 285 HP
Actually, the reason why the wax packing rope on your old Prostar was replaced with the dripless shaft seal was that it did have the issue of water entering the boat.
1996 Prostar 190, 350 TBI and Powerslot
Old 04-04-2010, 01:50 PM
carracer's Avatar
Thanks very much, I new that had to be it but hearing it from an experenced owner helped my O.C.D.
Old 04-04-2010, 01:55 PM
j2nh j2nh is offline
Excellent video on how to install and how a dripless shaft seal works, for the O.C.D. in all of us.
http://www.shaftseal.com/en/about/installation_videos
