  #31
Old 01-01-2010, 06:04 PM
kiteklan kiteklan is offline
Boat: Mastercraft Prostar 190 1997 ,with steyr 236 HP Diesel
Found some props need opinion
Originally Posted by TRBenj View Post
Very interesting project!
I think thats overly optimistic. You should find that the slip percentage will be in the range of 15-20% at best. The smaller, lighter, smaller wetted surface inboards Ive dealt with tend to run closer to 15%, while the newer slalom machines tend to run closer to 20%. You may be looking at a greater slip percentage with that huge reduction trans and super steep prop. If you break 40mph you'll be doing pretty good. Ive seen a few 95-97 Prostars flirt with 50mph, but that's with the 310+ hp V8's.
As far as prop selection goes, that is going to be a major hurdle for you. If you had a gearbox closer to 1:1 (as much as 1.5:1) you could probably find somthing off the shelf that would work- but with a 2:1 and a low RPM motor, youre off the grid for standard ski boat props. You'll want to narrow down your search by looking at props that are 12-14" in diameter- you wont fit anything bigger than that on the boat.
I found a manufacturer ,produces custom props, 4 and 5 blade I will use the original prop (1st photo) for 1st time testing after geting exact weight and measurements of draft and waterline,I am thinking to order a 5 blade.
Old 01-01-2010, 06:06 PM
DemolitionMan's Avatar
DemolitionMan DemolitionMan is offline
Boat: 2008 Pro Star 197 TT #58 of 100
Now that's a prop!!!
Automatic doors make me feel like a Jedi
Old 01-01-2010, 06:10 PM
dont you think it will work with a 2:1 transmission better then a 4 blade.
maybe also a lot of smoke
Old 01-02-2010, 02:50 AM
Before Video
http://www.youtube.com/watch?v=0v9PeQ8FRoc
I added a video on the youtube.
Old 01-02-2010, 09:22 AM
Interior and Dashboard
Today,we had received new covered seats and Interior and it is ready to install.
We still have the electrical work and the carpet issue.
Old 01-02-2010, 09:30 AM
Weight of Boat without diesel tank
Today we had lifted the boat with the interior and without the fuel tank.It weigh 1040kg ,2288 pounds. It think the final dry weight will be around 1300kg ,2860 pound.
How much an orginal mastercraft weighs?
Old 01-02-2010, 09:58 AM
mark g's Avatar
mark g mark g is offline
Boat: 2005 prostar 197, mcx
just had a look through it reads as having a weight of 2450 pounds
link to article below history of mastercraft
http://www.mastercraft.com/teamtalk/...ad.php?t=29236
Old 01-02-2010, 12:56 PM
Sodar's Avatar
Sodar Sodar is offline
Boat: '07 ProStar 197 w/ MCX
WOW!! Where did that interior color scheme come from!?!? Isn't the exterior purple and grey?
-Cameron
2007 ProStar 197
1996 ProStar 190
Old 01-02-2010, 04:10 PM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
A 5-blade would be interesting... what does a custom prop cost?
Did you reverse the picture that showed the original prop? It shows a RH prop, which wouldnt have been original.
Old 01-02-2010, 04:24 PM
I don't know where it came from but I like it.
diesel engine, renovation, repair, steyr
