Did you consider a 5.7 liter V-8 powered by propane? I know that's a good combo in europe as well. BTW, that gelcoat is looking good! 2-week project? That's awesome! Looking forward to the pics as things progress. Carpe Diem! ![]()
I was njskier on here. |
#12
On the positive side, diesels have tremendous low end torque so that may have some hole shot assistance.
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com SPECIAL PRICING CONTINUES Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. Spare tires too. |
#13
About Diesel engine Steyr 236
Transmission ratio is 2:1 which is not good that is I know but I will try to find a big prop with a high pitch.Other then that the engine is a 6 cylinder 3.2 liter gives max 440 Nm Tork at 3300 Rpm. I atttached the engine data in Pdf. 440 NM = 324.48 Lb/Ft is what this engine produces. RTP engine 310 HP 360 ft.lb. (488NM) MCX engine 350 HP 380 ft.lb.(515NM) VW TDI 225HP 335 lb (454NM) 1 foot-pound is closely equivalent to:1.3558179483314 newton meters I think in respect to fuel economy and performance ,overall we will get a 4/5. Thanks for the comments. Last edited by kiteklan; 12-31-2009 at 03:55 AM. |
#14
Why Diesel Engine
For the progress check the pictures .Name Stickers were for registration,we will work on something look nice with decals . |
#15
http://www.indmar.com/ProductLine/In...256/index.html
Inmar is using the same engine with 256HP,mine is 236. Last edited by kiteklan; 12-31-2009 at 03:43 AM. |
#16
I am pulling for ya! Hope you can make that combination work with some trial and error in the prop selection.
http://www.mastercraft.com/photopost...er=2572&sort=1 Need LT-1 parts? OIL FILTER: Factory installed is a Penzoil P23, Afta market brands, AC Delco PF-454 and a Fram PH-13 or PH-30 will work. SPARK PLUGS: AC Delco MR43LTS (gapped to .040") FUEL FILTERS: AC Delco 25171391 (pump inlet side) 89058397 (pump outlet side) IGNITION WIRES: Call Inboard Online @ (877) 327-7175 and order part numbers 556010A (odd bank) and 556010B (even bank) |
#17
JLeuck,I am really not sure about the end result,but made comparison with the figures above.I will post all the results here.
#18
End of year 2009
Check out the pictures.
#19
Wow, looks great.
'97 Prostar 190 - LT-1 Prior boats - 2009 X14, 2008 X14, 2005 197, 1988 Tristar 190, 1989 Prostar. |
#20
Very interesting using a turbo diesel in that boat. Do you think that the turbo is going to stay cool enough not to melt the engine box? I'll bet you can swing a rather large prop with a high pitch with that torqy motor. Do you know what the motor came out of?
| Tags |
| diesel engine, renovation, repair, steyr |
