  #101
Old 01-08-2010, 03:43 PM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
Originally Posted by kiteklan View Post
also ordered a flexible coupling between the shaft and the gearbox for a smoth operation on the gear changes forward to Neutral to Reverse.
I really wouldnt recommend installing this. We had one on one of our boats (came installed when we bought it) and it performed much better once we removed it. Its really a band-aid some people put on to hide misalignment.
The damper plate that resides between the engine and transmission is all you need... it will be smooth as silk compared to any outboard or I/O.
Old 01-08-2010, 03:47 PM
kiteklan kiteklan is offline
Boat: Mastercraft Prostar 190 1997 ,with steyr 236 HP Diesel
damper plate photo
TR,thanks for the advice,could you send me a photo of that damper plate or a reference?
Old 01-09-2010, 03:55 PM
mig mig is offline
Boat: 02 19Skier
It is Saturday here kiteklan and I am hoping for some on-the-water utube to watch!
Old 01-09-2010, 04:02 PM
cbryan70's Avatar
cbryan70 cbryan70 is offline
Boat: 1993 Prostar 205
ive been waiting all day
Old 01-09-2010, 04:37 PM
JLeuck64's Avatar
JLeuck64 JLeuck64 is offline
Boat: 98 Prostar 190 Stars & Stripes, LT1
Here's a pic from the back of my engine. I would assume your engine is already set up this way also. I would just align the engine/trans to the shaft and run with it too!
Need LT-1 parts?
89058397 (pump outlet side)
Old 01-09-2010, 05:11 PM
jLeuck thanks for the pictures,now I understand what you mean ,we have already the original part in between the Steyr and the ZF gearbox,What I am waiting for is the flexible coupling between the gearbox and shaft flange. It is a part like this sits just after the gearbox mounted to the flange and connected to the shaft coupling.
I need this part also for taking the propeller a little back to the end of the boat so I can use a higher diameter prop.
Old 01-09-2010, 05:18 PM
Parts Parts Parts
Sorry for that
I ordered a flexible coupling and the wrong part show up this morning so our lunch has postponed to Sunday afternoon.The part is coming from 1200km and right now it is on its way to mersin , instead of getting it posted with cargo we go with the old way,asked the supplier to correct his fault and send me the part with a passenger bus coming from Istanbul.Let's see if I will get the correct part in the morning I will post it here.
Old 01-09-2010, 05:52 PM
cbryan70's Avatar
and what will this part do? It should not shift hard into gear now with the damper plate.....
Old 01-10-2010, 01:48 AM
Flexible Flanga
Reduces engine noise and vibration coming from the prop .
Old 01-10-2010, 11:04 AM
JohnnyB's Avatar
JohnnyB JohnnyB is offline
Boat: 2004 Prostar 190
anxiously awaiting the results of your maiden voyage....take lots of pictures.
2004 Prostar 197, ACME 843
diesel engine, renovation, repair, steyr
