Old 12-21-2009, 08:26 PM
JLeuck64's Avatar
JLeuck64 JLeuck64 is offline
Boat: 98 Prostar 190 Stars & Stripes, LT1
Originally Posted by americanskierJim View Post
Here is a pic of the manifolds I am going to blast them tomorrow so I can repaint them. I am going to do the lettering in white and try and do the "V8" box in red with the V AND THE 8 done in white.
I have seen some guys paint the runners (portion of the manifold that is rusted) with a high temp heat resistant paint, like 1500 or 2000 degrees. Then paint the rest of the manifold with normal engine paint. It ends up looking great and it doesn't burn off!!!
Need LT-1 parts?
89058397 (pump outlet side)
Old 12-21-2009, 09:22 PM
markismm's Avatar
markismm markismm is offline
Boat: 1984 Stars and Stripes
That is what I did on my manifolds. I painted the non-water-jacketed portion of the manifolds with a high heat 550deg paint and the rest of the manifolds are painted with a 350deg wrinkle paint to change up the factory look. I am not a big fan of the gloss paint put on from the factory. In any event, I would definitely paint the runners with as high of a temp you can find or it will burn off and rust in the same place yours already have. Can't wait to see how they look when finished.
Old 12-21-2009, 10:02 PM
americanskierJim's Avatar
americanskierJim americanskierJim is offline
Boat: 1980 Mastercraft S&S Powerslot, 351 Windsor
Send a message via AIM to americanskierJim
TMCNO1, Thanks for the info I have a been looking at DIM book to get some new ones. I will get them apart and get them cleaned up and resealed. I also need to get a new damper plate the old one is a bad one.
JLeuck64, I do have 1500 paint I would hope that it doesnt burn off.
Markismm, I like the way you did yours I will keep all your tips in mind when I do these manifolds. Shouldnt be to hard to do.
Old 12-22-2009, 07:07 PM
Here is some pic's my friend found and sent to me of the boat when I got it. It was full of Hickory nuts to the edge of the lip. It took me a month of cleaning to get them all out. I pulled up the floor and checked the stringers and the in wonderful shape along with the bottom of the boat.
Old 12-22-2009, 07:10 PM
Here are some more to see.
Old 12-22-2009, 07:12 PM
Here is the last set of pics.
Old 12-22-2009, 07:13 PM
Sodar's Avatar
Sodar Sodar is offline
Boat: '07 ProStar 197 w/ MCX
Did you get any of the interior pieces?
Old 12-22-2009, 07:18 PM
HI Sodar, I do have all the interior pieces from the drivers seat to the rear seat just like that pic you sent to me of the LTD just like that. most of the wood frames will have to be rebuilt before the new skins get put on. I will get some pics of the seats sometime this week.
Old 12-22-2009, 07:27 PM
Sodar's Avatar
Just curious, since it seems the interior and special gelcoat are about the only things that differentiates an LTD from a standard S&S.
Old 12-22-2009, 08:44 PM
I got ya Sodar, It was a complete boat nothing missing as far as I can see. I like the set up for seating and all the drink holders it has that is a big +.
