| View Poll Results: Has Anyone Else Had This Issue? | |||
| Yes, and the Park Ranger KNEW how to decon the tanks |
0 | 0% |
| Yes, and the Park Ranger did NOT KNOW how to decond the tanks |
1 | 25.00% |
| No |
3 | 75.00% |
| Voters: 4. You may not vote on this poll | |||
Thread Tools | Display Modes |
Colorado and Utah are "cracking down" and requiring us to "decontaminate" the ballast tanks (X-15 w/3) if the boat's been in "contaminated" (with zebra muscles, e.g. Lake Pueblo) waters. SO FAR, the Park Rangers MUST complete this task (at, again SO FAR, no charge) - they will NOT accept "off premises" decontamination. Reference: http://parks.state.co.us/Zebra+Mussels.htm
My X-15 has THREE tanks (rear port, rear starbord, and center) with TWO input ports on the hull. I can't find ANY diagrams on which port feeds which tank. It APPEARS that the port intake feeds both of the stern tanks and the starbord intake feeds the middle tank; however, I want to make SURE so I don't burn out the pumps. Can I test "pump on" out of water without damaging the pumps? Obviously it would only take a second or two of pump run time (put my hand over the intake to feel the suction). Thoughts... Thanks for the help!! |
Invasive species are a problem in many waterways. Its inevitable that small boat ballast will be controlled in some fashion. My boat at times has 6 ballast tank/sacs, so it would be a pain. If they were to completely flood the ballast then your talking about 200 gallons, wow! Maybe i need to just stay home.
How did I ever live w/o my new 03 X-2?
Hi, KHall... As I understand it, if you have sacs, they do NOT need to be decontaminated. The only reason they are requiring decontamination of the "hard" tanks is that they do NOT typically empty COMPLETELY. CO has a cut off that will allow FIVE (5) gallons of water from one lake to another, or TWO (2) gallons PER TANK. With THREE tanks, like I have, that would equate to SIX gallons, which "forces" me to decontaminate. It's NOT that big a deal, only takes about an hour (they DO fill the tanks all the way to overflow), MAX, as long as everyone knows what they're doing (not ALWAYS the case), and they "tag" the boat. As long as you stay in the SAME LAKE, you do not need to decon the tanks each time. If you go to another lake, all "bets" are off and you need to re-decon. I just want to make sure, from a "boat plumbing standpoint" that I'm using the correct ports for the correct tanks so I don't damage the system. I THINK I've got it correct, as detailed in my message, but am NOT 100% sure. Don't stay home - ENJOY THE BOAT/WATER!!!
| Tags |
| ballast, decon, zebra |
