Old 10-21-2009, 10:10 PM
lfarris87
HELP! Boat wont accelerate!!!
Hello and thanks for taking the time to read this topic.
My buddy has a 2005 Xstar. And for a few weeks it has been doing this thing where when the perfect pass takes over it would do a very small surge of speed, then back to normal... then wwaaa... like a half a mile an hour tug... then back to normal for like 5 seconds then waaa... small tug...
Then the other day we were riding then it just stopped... You can put it in gear and idle but when you try to accelerate nothing happens... makes no difference wether the pp is on or not.... And also after you start it up an alarm goes off forever unless you flip the toggle switch that is below the key...
Has anyone had a problem like this? And if so... How can i fix it?
Thanks for your help!
Logan Farris
loganfarris87@yahoo.com
830-743-3567
Old 10-22-2009, 11:40 AM
wheeler's Avatar
wheeler wheeler is offline
Fuel pump may be the issue...
2004 X-10 MCX350
Old 10-22-2009, 11:58 AM
Jim@BAWS's Avatar
Jim@BAWS Jim@BAWS is offline
Logan Farris
830-743-3567
Make sure prefect pass is OFF Double check the link from the throttle body assembly
Jim@BAWS
Tampa Bay's Exclusive MasterCraft Dealer
www.BAYAREAWATERSPORTS.com
(813) 996-BAWS (2297)
Old 10-22-2009, 12:32 PM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
Doesn't sound like fuel pump.
Does the boat have throttle-by-wire? ICBW but I think the MCX in 2005 was the only engine with TBW. If no TBW, check and calibrate the throttle connection link and servo spool as described in Perfect Pass's instruction and troubleshooting manual (can be downloaded from PP).
If it's throwing an engine code, it would be helpful to know what that code is. Is it announced in the MFD? If not, may need to see someone with a marine code reader.
'04 MariStar 230VRS/MCX
Old 10-22-2009, 01:25 PM
WESSTAR's Avatar
WESSTAR WESSTAR is offline
Boat: X-STAR 2006 MCX
Did some research and found a bit about the surging problem. PP website says that it could be a bad ground and to check all wires at the ground bar and tighten as required. I have been having this problem hopefully will get the boat out this weekend and see if it fixes it.
'06 X-STAR
Old 10-22-2009, 05:08 PM
lfarris87
Thanks for the tips on things to look at guys.
Hopefully it will just be a bad ground or something.
Cause we also used to notice a coralation between turning up the stero loud and the Perfect Pass performing worse.
This boat doesnt have throttle by wire. And i was looking at the Throttle Body assembly and all the conections look good. No corrosion there or on the backside of the throttle it self. But im gonna go look into the grounds then try to check and calibrate the throttle connection link and servo spool as described in Perfect Pass's instruction.
Thanks and keep the ideas coming.
Old 10-22-2009, 08:22 PM
Jerseydave's Avatar
TT Hero
2 years ago my '05 X-star PP would surge badly. The dealer found a wire at the paddlewheel that needed to be repaired. (loose or broken, can't remember which)
All better.
There is also an updated chip from PP for the module under the dash. Call them about that too.
I was njskier on here.
accelerate, broken, xstar
