comments on 1993 stars&stripes-buying
considering buying a very clean 1993 stars & stripes with 285HP and 900 hours in very excellent condition.
does anyone know anything about this boat, amount of engine hours, and reasonable price? anyone have this boat or know someone who does? |
I have a '91, which is pretty much the same. Engine hours depends on the life the motor has had, and price depends on a lot of things
Lots of power is good, more is better, too much is just right. ![]() '91 prostar 190 |
I see you are new, welcome. You will find that is a very well liked boat on this board, especially for slalom. You will also find there is a lot of knowledge / detail on this board. I suggest you post pics of the boat for review (if possible). Also, inquire on maintentance history and how/where the boat was used. From that, you should get a lot of feedback, probably even sime price suggestions if you don't want to post the price on here.
I love that boat. I'd expect to see it in the $14K range just as a guess assuming it's in good shape. Maybe less due to a bit higher hours.
A couple of things. Does it have the stock carb (dual fuel line). If so, lake test it hard with lots of shut downs, restarts, and idling. My 4010 carb was a nightmare for us, even after a rebuild. Also, check the brake fluid on the trailer. In 93, they wrapped the brake lines in a rubber sheath and rusting out was very common. As for things to look for generally, this may help.
I bought a '92 PS205, and I think the only difference is that the '93 had FI.
Even if it's in good shape, with that many hours you should not go over $12K, IMO. If it's pristine, maybe *** high as $14K. My bow rider had 400 hours and I got it for $12,200, but that's the exception.
Some mornings it just doesn't seem worth it to gnaw through the leather straps. -Emo Phillips |
Hmmm.. double post.
Some mornings it just doesn't seem worth it to gnaw through the leather straps. -Emo Phillips Last edited by Muttley; 01-30-2008 at 06:23 PM. |
i agree with muttley, i would offer less even. boat is worth about 10-11max. unless you really have to have it.
I have a 93 Stars and Stripes, paid 14k for it with 350hours. It was in very good condition except for stitching coming loose on passenger seat and keel had some scrape damage that needed minor gelcoat repair. Trailer brakes as eastie said neeed attention. I replaced master cylinder and entire wheel brake assymbly just because it wasnt a major investment verses changing brake shoes. I have too had carb issues and replaced 4010 with 4560( I believe) which uses single fuel line feed. Easy job but worth it considering it now has zero issues with hot starts, etc. Awesome boat, I put perfect pass on it and love the slalom wake.
they want 14,000 for a perfect "10" boat. the owner/dealer wants to overhaul the carb and install a new distributor before i take possession. is this what you are referring to? |
If it's the original carb, try to work a deal for a Holley 4160. The stock carb was a 4010. It wasn't so much cold starts as it was heat sensitive. Once it got warmed up, it would be come hard to start and idled terribly.
Is it blue or red?
