Old 10-05-2009, 10:57 AM
BigJon BigJon is offline
Boat: 94 Mastercraft
Adding a battery switch
So I have encountered a dead battery twice at the docks, even though I have a new battery. Something is obviously draining my battery when not in use. i have a 1994 prostar and someone relocated the battery next to the gas tank behind the rear seat. So its a pain in the rear to take that out to charge or do anything.
I am wondering how hard it would be to wire a switch to the positive lead that goes to the engine. Lifting the doghouse is alot easier than lifting out the rear seat. If I could locate a switch there it would be a lifesaver. Also can you hook up your charger there somewhere instead of directly to the battery posts?
Old 10-05-2009, 11:27 AM
MCVOLS's Avatar
MCVOLS MCVOLS is offline
Boat: '08 X14 MCX Slot
On my previous boat ('93 PS 205) the battery was located next to the gas tank on the port side. I added a second battery in the same location, with a switch that was mounted inside the port storage/ski locker. To access the switch, I would reach into the storage, where it was mounted on the blockoff. This worked great for me for several years. This way, the switch was near the battery making the install simple, and it was not seen, but still easy to get to.
2008 X-14 MCX
1993 Prostar 205
1982 S&S
Old 10-05-2009, 11:34 AM
flya750 flya750 is offline
Boat: PS190
What about weight distribution? two batteries in the back corner?... heck.. I can tell what side the boat the cooler is on AND I can tell how many full beers we have left too...
Old 10-05-2009, 11:42 AM
MCVOLS's Avatar
I guess I let the cat out of the bag about how good a skier I am! I would love to be at a level where I could notice that, but unfortunately, I am not, so it was never an issue for me.
2008 X-14 MCX
1993 Prostar 205
1982 S&S
Old 10-06-2009, 11:11 AM
Miss Rita's Avatar
Miss Rita Miss Rita is online now
Boat: 1989 MasterCraft TriStar, 1991 Ski Pro
Overtons has a battery switch that would work great. It's on sale, only $17. You can put it on either the positive or negative cable. You'll need to use heavy duty terminals.
