Old 09-20-2009, 06:25 PM
jtrains jtrains is offline
Boat: Mastercraft X-30 2004 454
proper prop size and angle
I just posted a question about the strut. It was answered very quickly. Thank you.
I have another question about getting the proper prop.
The MC manual sais that the 2004 x-30 should have a LH 14 by 20 prop. That is easy to follow except I am putting a different size motor and transmission.
The original motor was the 350 with a Hurth 1:1.5 trans.
I am replacing the motor and trans with a big block 454 and a Velvet drive 72 or 71 model trans. I belive it is a 1:1 ratio.
The question is should I keep the recomended 14 by 20 prop size and angled prop or
down size the prop and angle for the bigger motor and 1:1 trans ratio.
Any info is greatly appreciated
Old 09-20-2009, 06:36 PM
Jim@BAWS's Avatar
[email protected] Jim@BAWS is offline
Your putting in a 1:1 tranmission in an X-30 that is designed for a
V drive 1.52 to 1.0
Bad move there
[email protected]
Tampa Bay's Exclusive MasterCraft Dealer
www.BAYAREAWATERSPORTS.com
(813) 996-BAWS (2297)
Old 09-20-2009, 06:40 PM
I'm putting on the bigger motor and trasmission because of the excellent deal that I got on the motor and trans. I got the x-30 as a project with out the motor and trans, that is why I'm putting anything at all.
How is it a bad mover? If the prop is resized and still a LH turn will it effect the performance?
Old 09-21-2009, 06:25 AM
EJ OJPROP's Avatar
EJ OJPROP EJ OJPROP is offline
The 1:1 gear ratio will not have the low end power that the gear reduction transmission provides. You will need to run a 13" diameter prop. I would do do what I could to keep the gear reduction.
