Old 09-17-2009, 08:06 PM
liledgy liledgy is offline
Boat: 1985 mastercraft 351
High idle after full throttle 351w PCM carburated
Boat has high idle after going full throttle. Shutting it of and restarting boat brings idle back to normal. Usually idles at 600 but goes to 12 to 1300 after full throttle.
Old 09-17-2009, 10:55 PM
ROB ROB is offline
Boat: MASTERCRAFT, MARISTAR 240, 1989, 454 INDMAR
Are you sure that you don't have a sticky throttle linkage. It could be as simple as some lubrication.
Old 09-17-2009, 11:32 PM
88 PS190 88 PS190 is offline
When my motorcycle did this it was the mechanical advance hanging up, cleaned and relubed and it solved the problem.
You don't mention what year your boat is, so I can't tell for certain if you have mechanical advance or electronic ignition with out. If you have a mechanical advance unit you can go to the FAQ in the general discussion section. There is an article about installing a conversion kit and it shows the weights under the point plate.
If its racing pop the cover check your thottle linkage, and then if not check those weights. Sticky or weak/broken springs and you could have that problem.
Old 09-17-2009, 11:50 PM
TMCNo1 TMCNo1 is offline
MC Hero
Boat: Gone
Here's the link to the tutorial showing how to remove the stuff and get to the springs and weights during the EI/Breakerless installation, http://mastercraft.com/teamtalk/show...1&postcount=25
Charter Member Number 1
Quote: 2RLAKE,
Old 09-17-2009, 11:57 PM
Carb linkages are designed to be operated without lubrication. When there is a problem with full range of operation not being available, it is usually because the linkage has accumulated some gunk and needs to be cleaned with carb cleaner. Of course that is in a perfect world and sometimes a little WD-40 goes a long way.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
SPECIAL PRICING CONTINUES
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 09-18-2009, 12:10 AM
I find graphite dry lube works pretty well for things like that. No grease/wax to gather gunk back up. And if you have a little tube of it around you'll find 1000 uses.
Old 09-18-2009, 12:48 PM
Thank you for the replys. I have an 83mc, but the boat invquestion is a 94 Bimini skier that my good friend owns. He bought this bought brand new after selling his 81 slot, most of his friends including me told him not to buy a off brand for $15000.00 and buy a used mc orbu or tique. Allhe heard from us was " it ain't gonna last". Suprisingly, this boat has been amazing! It's a mc knock off but it handles as good as any boat I've ever been in. It also has an articulating front scag which maybe the reason for the great handling. We ski on a private lake so it doesn't take the beating like it would on public waterways and he takes very good care of it( probably more so because of all of us former naysayers). I'm a MC guy but this Bimini is a great 3 event tournament boat.
Old 09-18-2009, 01:09 PM
Unfortunately I cannot tell you for sure what a 94 Bimini skier has for its ignition system. Should be quite similar though, often with some of the for lack of a better word 'off' brand boats they lag behind as far as say electronic ignition etc.
So I would guess it has a mechanical advance mechanism.
Old 09-18-2009, 02:00 PM
It does have electronic ignition. I am going to pass the info. On to him about the magnets and throttle cable.
Old 09-18-2009, 02:25 PM
MC Hero
Boat: Gone
Uhhhhhhhhhhh, what do you mean by "magnets"????????????
