Old 06-14-2012, 09:36 AM
michiganTristar michiganTristar is offline
Hoping someone can help out here! 89 Tristar 351, new battery, started right up drove across the lake and shut it off to suit up and then just 'click', sounds like the solenoid is engauging. tapped on the starter still no avail. the most noticeable thing is that the power lead wire (heavy gauge) running from the solenoid to the starter was extremely hot after only three short attempts at starting it. If i let it sit for a long time and the wire to cool and i hit the key the engine will spin about 2 degrees then stop again.
Thinking about getting a new starter today just looking for reasoning why it would just up and stop working and make the wire get so hot so fast?
Also i replaced at the start of the season all the leads that go to the battery and solenoid and starter so no corosion there.
Old 06-14-2012, 09:50 AM
Sounds like you have it narrowed down to the starter. It wouldn't hurt to have the starter tested before you buy new, but sounds like you have it handled.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
WEEKEND WHEEL SPECIAL
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 06-14-2012, 10:36 AM
DooSPX's Avatar
DooSPX DooSPX is online now
FYI since we are all talking about starters, etc. I replaced my starter w/ a Arco mini the other week for slow turn overs when hot or after sitting for a while.
here is how it went...
replaced starter- tried to start, click-click...
tried brand new battery that was on a tender- same deal
checked all positive and negative connections- same deal
all sourced back to the starter relay- replaced- seemed to fix it with out a hitch, super fast turn overs
for the heck of it, I broke apart the relay and the positive lead was hardly making contact with the plate behind it. You can see just a very small part of the lead was making contact.
Not saying thats your issue, but check in the order of this...
1. check all positive and negative power cables going from the battery to the relay to the starter
2. try a different battery
3. check neutral safety switch
4. check kill switch
5. starter
6. relay
A.K.A. One of a kind mistake
2011 Southern Owners Best In Show- 1987-2000 class
Trying to keep slalom alive
Need Parts or Services? Call BAWS 813-996-2297
Need a new prop to fit you needs? Call OJ PROPS 800-359-9730
Old 06-14-2012, 10:47 AM
LYNRDSKYNRD's Avatar
LYNRDSKYNRD LYNRDSKYNRD is online now
Boat: 1987 PROSTAR 190
Can you get the starter relay from auto parts store? thinking of changing mine for preventative measures.
Old 06-14-2012, 10:52 AM
As a general thumb rule, I always replace the solenoid when replacing a starter. Used solenoid goes into "known good parts box".
- Peter
TIRE & WHEEL SALES
Old 06-14-2012, 11:01 AM
Can you replace the starter with a standard starter from the auto store/also the solenoid in that case, if so does anyone know what the part numbers are. All I can find is skidim's parts and really don't want to waste this weekend off the lake. Only number I have is "59-2007" and "75-5005"
Old 06-14-2012, 11:10 AM
You need a marine starter, I do know that, they are sealed so your boat won't explode.
Old 06-14-2012, 11:11 AM
I replaced starter two seasons ago but not soleniod...
Old 06-14-2012, 12:23 PM
DooSPX's Avatar
I do not know if you can get the relay at an auto parts store. I ordered mine from SkiDim. 27 bucks
Old 06-14-2012, 04:12 PM
Yes your local auto parts store should have them, just take it with you so you can match it up. If you tell those guys it's for a boat they always have a puzzled look on their face, the last one I replaced I got from advanced auto and went with the motorcraft heavy duty type iirc less than an andrew jackson.
James
1989, indmar, solenoid, starter, tristar
