Back Binding F1 ski
ok, so have been without a boat for the last 3 years and now getting back into skiing.
I have an F1 ski with 2 double boots the problem is that my father was having trouble getting up with 2 boots so he ended up taking a razor blade to the back boot!!!! to some how make it into a slip on. I want the boot back. so I am looking for rear boot for an f1 ski. or a good place to find one. size large or extra large. Maybe some one else was having trouble and has an extra back boot hanging around. after purchases a real slip in rear boot. |
You can also check here, http://www.wileyski.com/catalogs/cat...&fileID=287439
Charter Member Number 1 Quote: 2RLAKE, At some point in time people need to wake up, remove their cranial intrusion into their own rectal areas, and take responsibility for their own actions. |
Maybe check out www.ski-it-again.com
Remember though Connelly change the hole pattern a few years ago, so depending on how old your F1 is, that will matter on buying one that will bolt right up without having to modify it to much.
1986 Mastercraft Skier w/ Powerslot |
I have a friend with a few year old F-1 and is dealing with the same thing. Pattern advice is right on. I told him to modify the plate or drill the ski. He seems hesitant to drill the ski. I don't get it, it's not like it's a 1,400.00 blank and IMO there should be no reason; if he's careful and fills the old holes it should be fine, right? Maybe I'm from the old school, but I never used to be afraid to drill or tune my skis.
"One foot in the grave, one foot on the pedal, I was born a rebel" Petty
After my last post I had a flashback to my most primitive wrap repair ever. I was at a 3 round tournament that used to be held in Greely, CO called the "Softwake Open" if I recall correctly. I ripped my wrap (rear) on my old Mastercraft Lapoint Mirage ski in practice and was bummed I had ruined my weekend. I made a run to a tire shop, they gave me a few old blown tubes and I went to work with a pencil using the old wrap as a pattern. I had to double the tube to get the tension right but it worked like a charm and I skied it for another 3 weeks until the new one came in. It was funny looking and I even intentionally left some of the writting on the tube visible and people got a good laugh out of it. People suggested electrical ties and shoestrings, but nothing beats a firestone lol.
Which bindings are on the ski?
There have been a few, iirc the most likely are either Stoker wraps or Vision plates? Old ones being yellow with a little ratchet strap thing across the toe? Does that sound right? Anyhow the old binding parts were NLA when I tried getting them from wileys and wiley's called connelly to try to see if there were parts. I ended up buying a Wiley's highwrap if you don't want to spend alot of change, and then in the future you'll never have to think about where to buy overlays etc. I do have a stoker rear in my closet, size large, I'll check to see if the overlay is torn very badly. |
#7
A couple years after I got my F1 I tore my back binding. Called Connelly direct and they sent me out a replacement at no charge. That was a couple years ago now and they may not still make the same binding, but it is worth a try. I just looked up the number on the internet and asked for customer support.
