Old 09-21-2009, 09:35 AM
Originally Posted by Jim@BAWS View Post
Remove the FUEL Pump and remove the small screen on the bottom. You will be a dental
pick.
Jim@BAWS
Is the part in bold type supposed to be an insult?
Old 03-11-2013, 09:45 PM
jwp1504 jwp1504 is offline
Boat: Mastercraft, x star, 2000, 330
Hey mate,
Thanks for your thread.. My 2000 X Star starting doing this on the weekend. I hit 3600rpm and it misses and carries on.
Here's the video http://www.youtube.com/watch?v=HjUXfXdh09Q
So you reckon if i change the coil packs i'll be sweet??
Old 03-11-2013, 11:31 PM
ricford's Avatar
ricford ricford is offline
Boat: 1996 Prostar190
Looks like you answered all your own questions. Glad you posted, though. It will probably help someone else.
Old 03-11-2013, 11:39 PM
BallBushing's Avatar
BallBushing BallBushing is offline
Boat: 1999 Maristar 210 VRS
I had the same problem with my 1999 LTR 330 hp in a Maristar. Turned out to be debris in the transmission cooler screen. Ran ok at low rpm but did not allow enough water at high rpm to cool the engine / transmission (still not sure which) and the engine would shut down down. Temp gauge never indicated overheating. Remove the hose and clean out the weeds, only took a bottle cap amount to cause the problem.
Old 03-11-2013, 11:42 PM
Originally Posted by jwp1504 View Post
Hey mate,
Reckoning isn't a good way to fix things and it makes the process very expensive.
Did you measure the fuel pressure and check for A) signal to the Ignition Control Module on the purple/white wire (WITHOUT piercing the insulation) or B) checking the quality of spark?
This could be a problem with the crank sensors, if you have the LTR. Run it under load when you do any testing- running it in neutral isn't going to give you the answers you need. I used to see that dip all the time on TBI engines and it usually was due to a clogged fuel filter or bad pump.
Old 03-12-2013, 09:57 AM
mwg's Avatar
mwg mwg is offline
Boat: 2001 Prostar 205V
Just curious, is the crank sensor specific to the Indmar engine or is it the same as the crank sensor found in a similar year GM vehicle?
Thanks
Old 03-12-2013, 10:01 AM
Thanks
Standard GM parts, but check them according to the manual- if they're dirty or mis-adjusted, they can cause problems, too. Pull one plug at a time and make sure they aren't dirty/corroded. If you do need new ones, verify the part number and make sure you mark the plugs so they go on the correct sensor- if they're swapped, it won't run at all.
Old 03-13-2013, 07:54 PM
Hi guys,
I have started a new thread...
http://www.mastercraft.com/teamtalk/...445#post915445
I have uploaded videos of the dash
Both videos are in gear but the speedo isn't working in one of the vidoes
