06 X2 General questions?
Picked up an 06 X2, MCX, PP, 48 hrs this weekend. Still can't believe it's in the garage!
![]() To save a bunch of searching and calling around, maybe someone with a newer boat can help me out. Raw water impeller, same as the older boats? (like my 96, Johnson 812 I think?) Ballast pump impellers, part #? Good aftermarket trailer place to get new oil bath hub caps and rear hub seals (1 cap is seeping oil, read about some aluminum ones???) Trailer wheel bearing oil, 75W90 75W140 gear oil? How to drain, pump out or siphon the fuel out? Can't get a hose down the fuel filler far enough to siphon. Don't want to disconnect one of the special fuel line fittings unnecessarily to pump the fuel out. Only way I saw was to pull the fuel pump or guage sender and siphon from there. Oil filter part #? (too lazy to pull the panel off twice!) Fuel filter location? In tank? Part #? 15W40 in the V drive, right? Can you hook up a raw water source (tee) into the raw water intake line to run it out of water (works well on my '96)? Vynil is either dirty or stained (brown) on the sunpad and top of the front seat cushion (white vynil). PO took it to a detail shop and they said it's actually some color transfer from the black cover being on it in the sun for extended periods and that a couple days good sun exposure will lighten it up and make it easier to clean. Tried a magic eraser and it cleaned it up maybe 50%, but that's alot of SF of vynil to scrub. To me it just looks dirty, because it's more brown than gray (black cover). Tried vynil cleaner, 303, oxy upholstery cleaner, they didn't work. Any miracle solutions here? Will have it in the sun this weekend and next, maybe that'll help. Thanks for any help here - Thrall
'06 X2 MCX "I understand why some people may not want to do this the way I have recommended but I can't understand the death grip some people have on a toilet plunger with a hose fitting." -JimN |
Don't know about the parts questions, but when I bought my X1, it had stains all over the sunpad from the shrink wrap and they were a biotch to get off. It took 303, magic erasers, tons of elbow grease and a lot of time to finally get them off. Be prepared to do it over and over again.
'06 X-1, it's red and white. |
Raw water impeller hasn't changed as far as I know.
Oil filter is the Pennzoil PZ-3 equivalent (I get the parts guy to cross reference it at the parts store) Same oil as the engine in the transmission, I recommend the Rotella, but any HD 15w40 will work as long as it meets the duty ratings (have used the Castrol Diesel oil before with success). Fuel filter is in tank, don't have the part number handy. When I run it out of the water, I actually use 1.5 inch tubing that I connect directly onto the raw water pump and run it into a bucket (I use a big cooler) of water. Even idling, the engine needs to pull more water than your house hose can supply, fill up the bucket, start the engine and run it until the bucket is empty, shut it off, wait to fill the bucket back up, run the boat again. If you are trying to heat the block up to change the oil, the easiest way is to just empty the oil after you get back from the lake. they take a long time to cool off and the oil will come out nicely even after an hour since it's been run. For the vinyl, keep with the elbow grease. The magic eraser will work, but make sure you put some 303 or some other conditioner after you are done, the harsh chemicals will dry out the vinyl.
____________________ 2006 X-2, MCX, Slate Grey w/ Pro Tour Red accents |
If your ballast pump impellers are the black ones, I recommend changing to the newer yellow ones, which are softer and more pliable. I had constant problems with the ballast pumps on my 05 X-2 until I switched from black to yellow impellers. No more problems.
Got all the filter #'s thanks for the help. WOrking on warranty on a couple fabulous GY Marathons and contacted Reliable axle about better bearing cap/sight glasses. Got a Flush Pro ordered too, to run it in the driveway. Keep working on the vynil. Gonna see if being out in the sun for a few days will break down the stains (a shop that the PO took it to said the UV rays would fade it and make easier to remove ).How can I get the fuel out of this thing???? Right now it looks like a 12' siphon hose and pulling something off the top of the tank to get in.
i think everyone is now switching over to the green impellers. the yellow ones allowed back flow to easy. sorry! ![]() |
#7
Really dying to find an easy way to get the fuel out of this thing!
#8
OK, I'm going to tell you what I used on the vynil that was quick and easy but I'm pretty sure I'm going to get blaseted for saying this. I had the exact same marks in the same locations and tried all the things you're doing. Made things better but didn't make the stains/marks or whatever they were go away.
While getting out some hard water marks and black marks off the fiberglass with some Mother's cleaner wax some accidently dripped on the vynil when the bottle fell over. Some of the wax had started to dry so I had to wipe and rub it to remove it from the vynil. To my surprise the wax (or probably more correct the cleaner in the wax) took the dark marks off the vynil really quick. I followed the cleaner wax with several applications of 303 over he next few days. I normally wouldn't even begin to think about using this type product on the vynil but after seeing the results of the area where the wax had spilled I decided to do the rest. It worked absolutely great. Can't tell at all where the marks were. The cleaner wax didn't seem to scuff up the vynil and I've seen no problems in the areas since doing this 2 months ago. Can't openly recommend you do the same as I wouldn't want to recommend something I'm sure MC wouldn't support. If you do try it start with a small area and se if it works for you. |
#9
Thrall, the pumps are behind the panels in the rear storage compartments, actually very easy to access and change (unlike the engine impeller).
Fyi, the resettable fuses for all of the pumps are under the back seats, big black box with 3 white buttons on it.
#10
Ttu, thanks for the info. I guess I was out of date. Black gave me constant problems (wouldn't fill, wouldn't empty). Yellow has worked great for me, but if I need new ones, I'll go green.
