  #4121
Old 01-25-2014, 08:48 PM
atihanyi atihanyi is offline
Boat: mastercraft prostar 190 1992 w/powerslot
I also have the three cupholders . Two are good one has a small crack if anyone needs them just cover shipping and they are yours
Old 01-26-2014, 04:19 PM
Inspected exhaust manifold bolts and tightened to correct spec' with my cheapo harbor freight 1/2 inch torque wrench.... all is well keeping these bolts sprayed with liquid wrench and corrosion protection has paid off. Loosened easily and torqued up easily..
anybody ever make a long allen tool to get a correct torque spec on the 2 inside riser bolts? Anything to feed the MCOCD beast - I am sure it would need double bend? What to the pro's do in at the dealers..
good 'n tight has worked but the winter is getting long in the tooth...
Old 01-26-2014, 06:17 PM
strad's Avatar
strad strad is offline
Well I ordered a new hour meter on Friday, and new dist cap and rotor for the new dist that I got. Still prestolite but the new one is screw down and the old is clip down. My hour meter runs slower than it should. Hopefully a new one will cure that. Do you guys see any problem with running 12 volts to it to run it up to the correct hours? Out of the boat I'm thinking.
Old 01-26-2014, 06:46 PM
Tristarboarder's Avatar
Boat: 2002 Xstar
One would think that a slower running hour meter is better than a faster running hour meter....better for resale
Old 01-26-2014, 06:49 PM
John 3:16-18
Boat: 2002 Xstar
To answer your question, you should be able to run a jumper wire from a 12 volt battery out of the boat and just have a good ground, and it will run all day long until you get your desired hours....I tested one out of the boat one time, and it ran normally
Old 01-26-2014, 06:54 PM
Dynamite Spike's Avatar
Dynamite Spike Dynamite Spike is offline
Boat: 1996 Prostar 205
Painted the frame around the windshield.
The boat goes to the upholsterers tomorrow for new carpet and interior.
Old 01-26-2014, 07:04 PM
what paint did you use?
Old 01-26-2014, 07:24 PM
strad's Avatar
Lol I agree with the resale angle! Although selling this boat would be painful. So it probably doesn't matter :-).
Old 01-26-2014, 07:33 PM
I used Rustoleum Semi-Gloss Enamel
