  #3951
Old 11-08-2013, 01:41 PM
Legolamb Legolamb is offline
Boat: 1996 Prostar 190, LT1
I used the same dryer exhaust hose as Mike, got mine at Menards and it has held up well.
Mike, is your rear floor screwed down? Mine is a floater right now due to the holes being rounded out and I was thinking about fixing that. Do you just re-drill the newly filled holes, or would using some type of insert and machine screw be the way to go?
Old 11-08-2013, 01:48 PM
scott023's Avatar
scott023 scott023 is offline
Boat: 2008 X45 Switch L18
I wouldn't go with the shiny stuff. It would take too much time cleaning and waxing it.
That's only funny beacuse it's true.
Roger that
Old 11-08-2013, 02:03 PM
Rockman's Avatar
Rockman Rockman is offline
You can either epoxy the holes and re-drill, use slightly bigger screws or drill new holes right next to the current holes...
I think our floor has 4 screws total and one is starting to not grab...may look at this as a project more over the winter....
Old 11-08-2013, 02:07 PM
I just redrill holes.. fill current holes with the epoxy - like rockman I have 4 screws to hold it down.. I am considering changing to a screw insert - haven't decided yet. Inserts would take more time with the boat...
Old 11-08-2013, 02:38 PM
prostar205er prostar205er is offline
Boat: ProStar 205, 1994, LT1
Cool thanks... got 25' of the aluminum type at Homedepot for $14.
Do you secure your hose at all? I need to replace mine as well. Can't recall though if it is anchored other than at the ends...
Old 11-08-2013, 03:15 PM
clamped at blower - I zip tie it along the way to the rear vent. Rear vent has a plastic assembly you can twist hose into.
Old 11-08-2013, 07:06 PM
scott023's Avatar
Roger that
Funny how well you can get to know someone on a boat forum.
Old 11-08-2013, 10:57 PM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
I brought my boat home today to go ahead and get the winterization and winter projects started. I was going to wait until after Thanksgiving but the weather is supposed to drop into the 20s for the low so I didn't want to take any chances. I drained the block before the drive home and I plan on running antifreeze through tomorrow. I have a little bit of oxidation both on my deck and hull so I started a little wet sanding. So far I am pleased as I only sanded with 1500 and buffed but I may have to go up to 2000 at least on the red gel. Below is the before and after on a section of the deck. I can't wait to get the entire boat looking like this.
Old 11-09-2013, 09:52 AM
Looks awesome...!!
