  #3911
Old 11-04-2013, 04:19 PM
Originally Posted by zsqure View Post
I could make all kinds of excuses, but it's just too dang cold to get in the water this time of year. I'm not 20 something anymore. Besides there are 4 maybe 5 weeks left to mow. After that I'll come up with some excuse to visit the old girl.
Did he just say not 20-something... - I wish I was 40 something... opportunity and time is the biggest factor up here.
Old 11-04-2013, 04:29 PM
scott023's Avatar
scott023 scott023 is offline
Boat: 2008 X45 Switch L18
Same factors even futher up here...
Old 11-04-2013, 05:49 PM
prop shaft is parallel to .003 - only took about 30 minutes...
Old 11-04-2013, 07:14 PM
sethro's Avatar
sethro sethro is offline
Boat: 1998 Malibu Echelon and 1985 Stars and Stripes
Was it off much?
Old 11-04-2013, 07:52 PM
Originally Posted by sethro View Post
Was it off much?
Just a bit... prolly .006 - .010
Old 11-04-2013, 08:36 PM
jgraham37128
How did you check it and adjust it?
Old 11-04-2013, 08:47 PM
TOO-TALL's Avatar
TOO-TALL TOO-TALL is offline
Boat: Mastercraft X2 2003 mcx
I feel the same.Plus riding in a dysuit...sucks!!!! and all the leaves floating in the river.
I said forget it.
Pulled all the gear out of the MC, put in sabil.Will fully winterize this weekend.
---Animal house
Old 11-04-2013, 09:16 PM
strad's Avatar
strad strad is offline
Got my new exhaust hoses and enough 1 inch hose to replace the intake to cooler section (rest was new already). Installed the new hose, and started my evaporust bath for the exhaust manifolds. Brought it inside the house so it will be warm enough for the stuff to work.
Old 11-04-2013, 09:30 PM
Loosened the coupling...separated coupling inserted feeler gauge. let the couple slight back a bit. use a feeler gauge to check coupling gap at 12:00, 3:00, 6:00 and 9:00 o'clock position. If too big for feeler gauge tight a bit.
If it's off in any of the positions you need to use the motor mounts engine position - up down left right...etc. there's a how to document here if you plan on doing it.
Just takes patience....
Old 11-05-2013, 10:13 PM
SP Maristar's Avatar
Did some polishing on the dangly bits.Name:  ImageUploadedByTapatalk1383707611.505813.jpg
