  #3801
Old 10-18-2013, 02:12 PM
bill-d-c's Avatar
bill-d-c bill-d-c is offline
Boat: 1998 Maristar LT-1
Read somewhere that Seafoam lasts longer than Stabil - I still use Stabil Ethanol Treatment at fill ups - but always dump a appropriate amount of seafoam for layup.
Seafoam itself is a fuel stabilizer...
Is this a special type of Sea Foam, or the same kind you pick up for injector cleaning? Also, how much would you use for 30 gal., one can be enough?
Thanks,
Bill
Old 10-18-2013, 02:17 PM
Sta-bil Red says it will keep fuel fresh for 12 months.
Old 10-18-2013, 02:24 PM
SO will Seafoam - I believe fuel stabilization is not hard these days.. and I don't get 10 months of snow peter.. 20 weeks is all I need to stabilize... ...
Old 10-18-2013, 02:25 PM
prostar205er prostar205er is offline
Boat: ProStar 205, 1994, LT1
Bought the balance of my winterization supplies...
VR-1 20w50 Synth
Napa 41060 - upgrade version of 1069
Napa 3003 - in line fuel filter - goes before pump
Sea Foam - stabilize fuel
hope to hold off on winterization - but work alas is getting in the way and the weather slipping away..
Sad day Mike... The 50-degrees outside doesn't help much either! What happened to fall?
Reading your post I realized I remembered everything with my winterization...EXCEPT Stabil. Duh. I assume pouring some in the tank is better than nothing, even though it won't make its way through the engine. (Since I've already fogged the engine, I didn't think I should turn it over at all.) Thoughts? Reprimands?
Old 10-18-2013, 02:27 PM
Thanks,
Bill
My MCOCD would put 2 bottles of Sea Foam in - Red Stabil is cheaper...
With the risk of the flame thrower coming out.. -- I even put MMO in my gas. Just a couple ounces per tank at every fill up. Probably not necessary - but it gives me piece of mind..
Old 10-18-2013, 02:28 PM
bill-d-c's Avatar
My boat could end up sitting half way through next summer before use. I'm going to winterize it tomorrow, want to use the best stabilizer I can. I've always used Sta-bil in the past, but if there is something better out there I'd switch.
Bill
Old 10-18-2013, 02:31 PM
No - I would throw sum in the tank... fuel in the line should be ok.. imo.. no air sitting there with fuel to oxidize..(right James and JimN?) ---
Reprimand.. grab beer sit in boat make motor sounds - sip beer - repeat..
I always put the witches brew in my tank... I have made many friends on this forum - upside -- lot's more fun and skiing.. downside my boat sits more often...
Old 10-18-2013, 02:34 PM
Bill
I am sure they are both good - I have read nothing but good things about both products... over all. From personal experience - my motors start better after layup now that I have used Sea Foam.
My 1986 Johnson Outboard starts first time after laying up for 49-50 weeks each and every year since 1986 - She sleeps in northwest ontario near Medimoose..
Old 10-18-2013, 03:10 PM
Ha! I figured I'd just pour it in there and see how it goes. If memory serves me well I have done this before and didn't have an issue. (On second thought, obviously my memory isn't serving me to well...)
In any case, good to know I have you down the road to help me figure it out in the spring!
Old 10-18-2013, 03:21 PM
It might help to cycle the key a couple times once the stabil is in the fuel tank. It might not do anything, but you will feel better for doing something.
