  #3731
Old 09-27-2013, 10:35 AM
clrussell's Avatar
Mike I didn't put thread lock on any of my bolts. Mine had lock nuts on everything and they still felt like they were doing their job. I've never put loctite on spring bolts or u bolts.
I will say though, changing that spring was the easiest spring I've ever changed, didn't break or strip a single bolt, everything came off easy
Old 09-27-2013, 10:41 AM
Originally Posted by clrussell View Post
Last night I replaced passenger side leaf spring, thought it was broke or sagging as the tire was rubbing the fender. No change after new spring, don't see anything bent. So I added a 1/2" block under the spring welded to the axle. Back to normal height. It's just like the boat was heavier on that side? Nothing what so ever in the boat though.
Then I fabricated round 2 of fae, more conventional this time and I think it'll function great. Trying it out tomorrow! Attachment 101598
Spring must not have been an exact match. Not surprising. My MCOCD would have me changing the other spring as well.
Nice work on the FAE.
Old 09-27-2013, 10:43 AM
Replacing both springs this winter... do you recommend thread lock for the bolts? Mine are just 18 years old... the metal can bounce only so long... right?
Lock-nuts are the norm for trailer suspension fasteners.
I plan on new springs and hardware in spring......the one time I would prefer a single axle trailer.
Old 09-27-2013, 11:11 AM
clrussell's Avatar
The other spring will be changed this winter, I had to have this one on there to go to the lake tomorrow!
Old 09-27-2013, 11:16 AM
I figured that was the answer.
Old 09-27-2013, 12:14 PM
clrussell's Avatar
Yep, gotta get on the water while I still can!
Old 09-27-2013, 01:13 PM
What size springs... I tried measuring mine jacked up - couldn't get a number to match what I can buy.
Old 09-27-2013, 01:41 PM
clrussell's Avatar
I think the spring I got was 27" center eye to center eye, 1&3/4 wide 4 leaf. I can get the part # for ya. My dad being a trailer parts guy had me one the next day. Maybe I can find a part# and brand
Old 09-27-2013, 01:57 PM
prostar205er prostar205er is offline
Boat: ProStar 205, 1994, LT1
Nice!
Old 09-27-2013, 02:01 PM
Thanks for the info. What did you use against the hull that would protect but not slip?
Originally Posted by Lumbergh View Post
To get the entire hull, I took my 3.5t (Arcan - Costco {all steel}) jack, put about 5-6 (4" square) pieces of 2x4 and jacked toward the rear of the hull (behind the trailer fender) on the edges (figured that was the safest/strongest area).
Got 3" or so clearance along the entire bunkboard, sprayed Starbrite on kitchen sponge (wearing latex gloves of course). Cleaned the entire bunk-hull area clean. Rinsed well.
Boat just rocked over on opposite bunk, still totally stable on trailer.
For the front I disconnected everything and jacked on keel. Boat sort of pivoted enough to get under front v carpet resting area.
Not terribly difficult.
I have MCOCD. Maybe not as much as some around here, but it is an affliction.
Now boat is taking its long winter nap, happy,warm and dry in my garage.
