  #3631
Old 08-05-2013, 08:29 AM
Josephmattison Josephmattison is offline
Boat: 1987 pro star 190 351 Windsor
Send a message via AIM to Josephmattison
New valve seals rebuilt carb new starter new Johnson raw water pump all new fuel lines new fuel pump rebuilt distributer new plugs and Mallory plug wires new valve cover gaskets painted exhaust manifolds new interior new sound system new decals and most important a new wolf whistle horn lol didn't do this in a day it took around a month but its looks good and runs perfect (1987) MasterCraft Pro Star 190
Old 08-05-2013, 08:54 AM
Mark rsa2au's Avatar
That's a lot of work! Glad it runs perfectly. Well done!!
Old 08-05-2013, 10:45 AM
Dynamite Spike's Avatar
Dynamite Spike Dynamite Spike is offline
Boat: 1996 Prostar 205
Rewired the trailer (and the wiring to the trailer connector on my truck)
Why is it that trailer wiring is often done so badly? The PO must have no pride in his work...or just had no idea!
I HATE those splices that clip onto an existing wire and cut through the insulation to the wire.
Do it properly or give it to someone who can....or don't do it at all !!!
Old 08-05-2013, 06:47 PM
JDC's Avatar
JDC JDC is offline
Boat: 2004 Prostar 209 - MCX
Mine has several of those crappy crimp connectors too. I'm dreading having to redo mine.
The only time anyone should consider using those crimp/cut into the wire connectors is when the connection will be weather protected, like maybe behind the dash for a non critical item. On a trailer that gets dunked in the water?!, just makes you shake your head.
My M/C dealer has a complete wiring harness that uses the coiled cord with the 7 pin round connector to the tow vehicle. I'll probably get that and just start from scratch... one of these days.
Jeff
Old 08-05-2013, 07:01 PM
LaRue's Avatar
LaRue LaRue is offline
Boat: 2000 Mastercraft Maristar 210 LTR
Washed...wiped down seats and interior... vacuumed...fixed light on trailer
Old 08-05-2013, 08:39 PM
Over the weekend I replaced all the electrical connectors. I crimped, soldered and shrink-wrapped them all. There were several splices that needed replacing as well as shortened the wire for the Arco starter I installed a couple weeks ago.
I also ran a separate ground wire for the blower. I was getting some feedback coming through the oil and temp gauged. The blower is in the back of my '77 and the existing ground just wasn't enough.
Old 08-05-2013, 08:49 PM
Getting my stuff together to change fuel lines... found a shop in downers grove il, now just need to find a source for fittings... will prolly buy the lines and and and bring old line to fabricator.
going to make 2 fuel lines out of the one so I can have a better union for the in line filter before fuel pump... the hose clamps I have now have me always thinking... even though I like the see through filter of the napa 3003 filter.
thinking hose with fittings to canister filter Napa 23481 then another hose with fittings to fuel pump.
Old 08-05-2013, 09:27 PM
Traxx822's Avatar
Traxx822 Traxx822 is offline
Have you ever heard if it ain't broke don't fix it?
1 Corinthians Chapter 13 - 11
Old 08-05-2013, 10:15 PM
I also heard of - "maintenance keeps your boat on the water... "
Old 08-05-2013, 10:17 PM
Traxx822's Avatar
Really, my boats always in the water. You can't use that one me.
