  #3621
Old 07-30-2013, 01:55 PM
Burbon66's Avatar
Burbon66 Burbon66 is offline
Boat: Mastercraft X-9 2002
Thought I would give the carpet a hit with the Karcher. Wow. Before on the left and after on the right of the photo Name:  ImageUploadedByTapatalk1375203336.760567.jpg
Old 07-31-2013, 10:34 PM
nickespi's Avatar
nickespi nickespi is offline
Boat: 2002 MasterCraft X-30
Got my speaker rings back from the machine shop. Had the factory Clarion rings tapped and milled to accept Wetsounds. Speakers are now on the tower. First impressions are good. The speakers sounds extremely clear and crisp. Can't wait to get them on the water and test them out.
Old 08-01-2013, 12:02 AM
Spent some time trying to find the source of a backfeed causing the temp and oil pressure gauges to read higher when the blower is on. Found a break in the ground gang that I apparently soldered when I first got the boat. Solder joint let loose and ground is poor. Better with a jumper wire temporarily in place but still tracking down the remaining bad ground. Also found a fuzzy connecting in the harness under the dash. Next year I will be wiring in a new fuse box that is NOT on the underside of the dash.
Old 08-02-2013, 04:11 PM
1redTA's Avatar
1redTA 1redTA is offline
rebuilt the carburetor, it wall full of corrosionName:  ImageUploadedByTapatalk1375470361.021696.jpg
Size:  64.7 KB from ethanol and neglect on my part from running ten gallons of ethanol gas with no marine stabil only sea foam.
I soaked the carb in a bucket with warm watsr. vinegar and 4 efferdent tabs ( thanks Garage Journal ) it stripped all the plating and dirt off the carb very nicely.
Since the plating was gone and the season is in full swing I am waiting to send the carb back to Holley for plating and opted for some engine paint and primerName:  ImageUploadedByTapatalk1375470622.087919.jpg
Size:  97.5 KB. I know this is a temporary fix but decided I'd try it for fun
1981 MasterCraft
19' Skier 351W PowerSlot
Old 08-02-2013, 09:52 PM
MI_Corey's Avatar
MI_Corey MI_Corey is offline
Boat: 2008 X1
Tore my old fuel sending unit apart and used epoxy to put the magnets back in the foam. Now I have a working gauge again.
Old 08-02-2013, 10:29 PM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
Fixed loose ground on the trailer wiring and installed a new 12v outlet in the bow for the tsunami pump.
Old 08-03-2013, 03:00 PM
carlsonwa's Avatar
carlsonwa carlsonwa is offline
Boat: 2006 Prostar 197 TT
Removed the warning stickers. The font was disappearing anyways.
Then gave her a good mid season wash and wax. Using Mequiers flagship wax.
Ready for the lake tomorrow!
Old 08-03-2013, 03:19 PM
atlfootr's Avatar
atlfootr atlfootr is offline
Boat: Barefoot 200 MasterCraft 1993 ProV200 Outboard
Easy fix, unscrew then retighen
NEW SKINS ...
Jim - "Upholstery Guy"
(865) 995 0607 Hm (BSURE 2 LVMSGE)
(865) 679 2246 Cph (ANYTM UPTO 9PM EST)
[email protected]
I've got badass '93 MC BF 200 w/ a Yahamie ProV 200.
M O S T A W E S O M E C R A F T E V E R B U I L T
'Luv'n life behind a Barefoot 200'
atlfootr
Old 08-04-2013, 04:23 PM
KahunaCraft's Avatar
Boat: 2012 X30, 6L
Added this temporary improvement to avoid the situation where it gets kicked and fills one of the hard plumbed sacs ... Ironic I put the super sacr there to avoid that in the first place.
I'm going to either find or make a better switch guard.
Old 08-05-2013, 06:54 AM
petermegan's Avatar
Hi Kahuna, Could maybe use something like this:
http://www.ebay.com.au/itm/AEROFLOW-...12279a7&_uhb=1
Have Fun........
