#2571
No doubt experience goes a long way here.
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com SPECIAL PRICING CONTINUES Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. Spare tires too. |
#2572
I didn't buy one until I put a new carb on the 92. I figured I just spent $500 bucks on a carb I might as well get the 15 dollar gauge. It did seem to make a nice difference in idle and just off idle performance.
When is your birthday? Maybe TT members can chip in and get you one!! ![]()
Gone, surfing. |
#2573
Idle mixture screws wont change plug readings. They are for adjusting idle mixture and will normally only affect idle and just off of idle performance. Unless you have some sort of vacuum leak, plug readings normally just show WOT fuel/air mixtures which are controlled by jet sizes.
Gone, surfing. |
#2574
#2575
But, maybe I am confused as to what people are actually talking about.
Gone, surfing. |
#2576
Tim
Bday is actually in 11 days lol. Ok guage that I'm headed to go get now. Hook guage to a vacuum port on carb or intake. Does it matter. My screws are 1.5 turns currently. Screw both ways until say port side raises vacuum to highest point. Move to starboard side and make vacuum go to highest point. Roughly rpm should rise and both screws should be X.X turns on both sides of metering block. Lower idle to 800 Call it good Is this correct? Now on my boat after sitting turned off for 5-10 min I must re pump throttle for start. I don't get that but after starting it is fine. Fuel is either evaporating or something. Basically a few squirts and all is good. I can fix anything and build cool stuff but I never learned about carbs in tech school. It was all efi. Obd 1 and 2. I'll take any advice that you are willing to share.
Rollin' Gangsta Style Quote:
#2577
You need full port vacuum, I suggest the manifold.
Make sure the engine is at operating temp and that the choke is completely off/open. You may want to check your choke adjustment, it might help with the warm start needing a squirt of fuel issue. The reason for turning the screws all the way in and back out is to make sure they are the same, your carb 1.5 on both sides is fine. After obtaining the highest vacuum reading by adjusting the mixture screws return the idle to the desired number and recheck the idle screws. Attach your vacuum gauge and start by turning one screw 1/4 to 1/2 turn in. If the vacuum goes up then do the same to the other side. If the vacuum goes down then turn one screw out 1/4 to 1/2 turn out. Keep doing this until you get the highest vacuum reading. The desired outcome is maximum vacuum at your desired idle. So once you get max vacuum and then adjust your idle you'll want to check the vacuum and idle mixture screws again. Adjusting the idle will affect the vacuum. I think I have a howto on mixture screw adjustment on here I just can't seem to find it.
Gone, surfing. Last edited by CantRepeat; 03-08-2013 at 03:03 PM. |
#2578
Put it in the water for the first time today. Started right up. Smooth water, but still 47 degrees. Topped out at 42mph. Left it in a friend's boathouse to work on the trailer. Removed the old bunks, carpeted new bunks for the trailer, got new tires installed, changed the oil in the hubs, removed some rust from the torsion axle.
2003 X2 |
#2579
Primed and painted the torsion axle, installed the new bunks, and carpeted the boat buddy.
Before ![]() ![]() ![]() Surface Rust Removed ![]() After ![]() ![]() ![]() ![]()
2003 X2 |
#2580
what did you use to clean rust - media blasting?
