  #2551
Old 03-07-2013, 10:46 PM
Originally Posted by Kyle View Post
I picked up Rats boat "The Douche Canoe" and adjusted the carb.
It needed air mix adjustment, accelerator pump adjustment, and idle adjustment.
Lake tested it for an hour and she runs top notch now. I got rid of the hesitation and made her scream. Meanwhile Rat was at work and getting my texts and videos while driving his boat around on a warm day while he was stuck at a desk.
He now has a real nice hole shot.
As soon as we get rid of three feet of snow and three feet of ice I will be able to have fun like that.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
SPECIAL PRICING CONTINUES
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 03-07-2013, 10:50 PM
Kyle's Avatar
Kyle Kyle is offline
Boat: 93 Prostar 190
Move to Texas.
It is full of great people and we don't have the harsh winters. Mid 70's today......
Rollin' Gangsta Style
Old 03-07-2013, 10:59 PM
jhall0711's Avatar
jhall0711 jhall0711 is offline
Boat: None
Hey Kyle does the "Douche Canoe" have a 4160? I have always thought I had a bit of hesitation and would be curious to hear your technique for making adjustments.
Old 03-07-2013, 11:33 PM
Kyle's Avatar
Yes a 4160
Run the air mixture screws in and count the amount of turns to tighten both screws in. Both screws are on the front bowl one on each side. Write the amount of turns down.
Back screws off 1 1/2 turns each.
Start the boat and set idle at 800 rpm
If you have hesitation then you probably have a weak accelerator pump spring or it is adjusted not tight enough. With a pair of pliers and a 3/8 wrench, tighten the accelerator pump spring. You can only make 1/8 to 1/4 turns. Tighten a few turns. I did 5 per time. Basically did 5 1/8 or 1/4 turns. Tested it. Hesitation started going away so I tightened more. Basically I kept tightening until it ran properly.
When I first started it was so bad that from idle to wot the boat would die. Now it can go from idle to wot and the hole shot grips and rips out of the hole and hauls ars. Everything is all good now.
If tightening makes it worse then listen the accelerator pump spring. But I bet it needs tightening vs loosening. You probably are starving for fuel when you mash the throttle.
Hope this helps
Old 03-08-2013, 12:31 AM
jhall0711's Avatar
Boat: None
Is there a reason to count the Air Mixture turns to tighten if they are just getting set at 1.5 turns out? Just for reference in case it gets worse?
Old 03-08-2013, 12:50 AM
Kyle's Avatar
Correct. Incase it was better before with X turns in. That way you can put it back to where it was before.
Old 03-08-2013, 01:01 AM
jhall0711's Avatar
Boat: None
I really do not feel a lot of hesitation coming out of the hole.... It seems to go pretty good there... What I notice is when pulling a footer... and I try to go from that mid 20's to foot speed. When I hammer it at about 22-25 it seems to lag; granted for just a split second. I assume its in the carb if anywhere. Could be wrong; and it could be completely normal.
Old 03-08-2013, 01:14 AM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
Installed a new impeller and put the sacs back in today. Putting it in a friend's boathouse tomorrow to do some trailer maintenance over the weekend.
2003 X2
Old 03-08-2013, 01:25 AM
Kyle's Avatar
Make sure that the secondary diagram is good. When you hammer down look at the secondaries should open.
I would stand over engine while someone hammers down and watch the fuel spray in all 4 barrels. Then make sure the diaphragm is good.
If you can hammer down from idle then adjust the accelerator pump last.
Old 03-08-2013, 05:57 AM
Boat: Boat
You need a vacuum gauge and a tach to adjust the air mixture screws correctly. You'll never get them dead on with the butt dyno.
http://www.chevyhiperformance.com/ho...8/viewall.html
http://www.onedirt.com/news/how-to-p...y-carburetors/
Gone, surfing.
